Teraz jest 20 lut 2018, o 11:29
Utwórz nowy wątek Odpowiedz w wątku  [ Posty: 23 ]
 Tytuł: Kody błędów
PostNapisane: 23 lut 2007, o 20:41
Pochwały: 56
Podstawowe kody błędów sygnalizowanych przez lampkę Check-Engine (Malfunction Indicator Lamp):
1 Normal Condition
2 Air Flow Meter signal
MANIFOLD AND/OR AIRFLOW METER SENSOR circuit
- AIRFLOW METER/circuit
- MANIFOLD PRESSURE SENSOR/circuit
3 Ignition signal
-NO "IGF" SIGNAL to ECM
-IGNITER/IGNITER CIRCUIT
-IGNITER AND IGNITION COIL/circuit
4 Engine Coolant Temperature Sensor signal
- OPEN or SHORT IN WATER TEMP. SENSOR
- WATER TEMPERATURE SENSOR circuit
5 Oxygen Sensor OXYGEN SENSOR SIGNAL/OXYGEN SENSOR HEATER Signal
OPEN OR SHORT IN OXYGEN SENSOR OR OXYGEN SENSOR Signal
6 RPM signal (Crank Angle Pulse) RPM Signal
- NO SIGNAL to ECU FROM DISTRIBUTOR ("Ne" or "G") AFTER ENGINE HAS BEEN CRANKED
- DISTRIBUTOR/circuit
- STARTERSIGNAL circuit
- IGNITER/IGNITER circuit
7 Throttle Position Sensor Signal
- OPEN or SHORT Signal
- TPS SENSOR
- TPS Signal/circuit
8 Intake Air Temperature Sensor Signal
- Open or short INTAKE AIR TEMP. SIGNAL
- INTAKE AIR TEMPERATURE circuit
- INTAKE AIR TEMPERATURE SENSOR
9 Vehicle Speed Sensor Signal
-NO SPD. SIGNAL FOR SEVERLA SECONDS WHILE VEHICLE IS OPERATED UNDER HEAVY LOAD
TPS/MAP/AIR FLOW INPUTS)
- SPEED SENSOR/circuit
10 Starter signal
11 Switch signal LOSS OF POWER SUPPLY TO ECM
-IGNITION SWITCH/circuit
-MAIN RELAY/circuit
12 Knock Control Sensor signal
STARTER SIGNAL
- NO "STA" SIGNAL TO ECM UNTIL ENGINE SPEED EXCEEDS 800 RPM
- IGNITION SWITCH/circuit
12 RPM signal (G22 for –FSE)
- NO SIGNAL TO ECM FROM DISTRIBUTOR ("Ne" OR "G") AFTER ENGINE HAS BEEN CRANKED
-IGNITER/IGNITER circuit
12 Crankshaft position (CKP) sensor - circuit malfunction (3C-TE)
13 Knock Control CPU (ECM)
13 RPM signal (NE for –FSE)
SAME AS above but after ENGINE has RUN AT 1,000 - 1,500 RPM
-DISTRIBUTOR/DISTRIBUTOR circuit
13 Fuel injection pump position sensor – circuit malfunction (3C-TE)
14 Turbocharger Pressure
14 Ignition signal
- No "IG" or "IGF" ignition signal to ECM from ignitior several times in succession (IGT1, IGT4, IGF for –FSE)
- NO "IGF" SIGNAL TO ECM
- IGNITER AND IGNITION COIL/circuit
14 (2C-TE) Timing control system malfunction
15 Ignition System (IGT2, IGT3, IGF for –FSE)
15 (1CD-FTV) Throttle motor - circuit malfunction
15 Throttle control circuit - malfunction
16 Faulity in transmission/transaxle ECM (Transmission control signal)
17 Engine control module (ECM) -malfunction
18 Fuel quantity adjuster -malfunction
19 Acceleration Pedal Position (AAP) Sensor/Switch circuit malfunction (VC, VPA, VPA2, E2 – for FSE, 3C-TE)
21 Oxygen Sensor
OXYGEN SENSOR SIGNAL/OXYGEN SENSOR HEATER SIGNAL
- OPEN or SHORT IN OXYGEN SENSOR OR OXYGEN SENSOR SIGNAL
22 Engine Coolant Temperature Sensor signal
- OPEN OR SHORT IN WATER TEMP. SENSOR SIGNAL
23 Intake Air Temperature Sensor signal
- OPEN OR SHORT IN INTAKE AIR TEMP. SIGNAL
24 Intake Air Temperature Sensor signal
25 Air-Fuel Ratio Lean
- LEAN SIGNAL SENT TO ECU FROM O2 SENSOR
- INJECTOR FAULT(S)
- FUEL PRESSURE
- OXYGEN SENSOR
- AIRFLOW METER OR MAP SENSOR
- IGNITION
26 Air-Fuel Ratio Rich
- SAME AS ABOVE
- COLD START INJECTOR
27 Sub Oxygen Sensor signal
- SUB OXYGEN SENSOR/HEATER circuit
28 No. 2 Oxygen Sensor signal
No.2 OXYGEN SENSOR/OXYGEN SENSOR HEATER
- SAME AS CODE 21
29 No. 2 Oxygen Sensor signal
31 Air Flow Meter signal or Vacuum Sensor signal circuit
- AIRFLOW METER/CIRCUIT
- MANIFOLD PRESSURE SENSOR (MAP) circuit
32 Air Flow Meter signal (VANE-TYPE)
32 (Diesel) Malfunction Resistance Signal
32 (2C-TE) Module coding plug - malfunction
32 (1CD-FTV) Injector - malfunction
33 IAC Valve
- OPEN OR SHORT IN IDLE AIR CONTROL VALVE Signal CIRCUIT or IDLE AIR CONTROL VALVE or ECM
33 Intake manifold air control solenoid –malfunction (3C-TE)
34 Turbocharger Pressure signal
- ABNORMAL TURBOCHARGER PRESSURE
- TURBO CHARGER
- AIRFLOW METER/MANIFOLD/TURBOCHARGER PRESSURE Signal
- INTERCOOLER SYSTEM
35 Turbocharger Pressure Sensor
- TURBOCHARGER PRESSURE SENSOR (Gas.)
35 Manifold Absolute Pressure Sensor (Diesel, 3C-TE)
35 HAC Sensor signal
-OPEN CIRCUIT IN HIGH ALTITUDE COMPENSATOR Signal
36 Sensor Combustion Pressure (Toyota Part No. 89468-20020)...
39 (Avensis) Fuel temperature sensor - circuit
39 VVT-i Valve (p1656,p1345,p1349, OCV for -FSE)
39 Fuel temperature sensor - circuit malfunction (3C-TE)
41 Throttle Position Sensor signal
- OPEN OR SHORT IN TPS Signal
- TPS Sensor
42 Vehicle Speed Sensor signal
- NO SPD. Signal for SEVERLA SECONDS WHILE VEHICLE IS OPERATED UNDER HEAVY LOAD (TPS/MAP/AIR FLOW INPUTS)
- SPEED Signal circuit
43 Starter signal
- NO "STA" Signal TO ECU until ENGINE SPEED exceeds 800 RPM
45 EGR System malfunction
- VSV EGR
- Temperature Sensor
47 Sub-Throttle Position Sensor
- Open or short circuit in Sub-Throttle position sensor signal
47 Throttle position (TP) sensor
48 Vacuum Switching Circuit of Air Sw. Valve or Air Pump (EAP) Malfunction
49 for D-4 System SFP (PR, VC, E2 for -FSE)
51 Switch signal
SWITCH Signal IDL (tps) CONTACTS OFF, NEUTRAL START SWITCH OFF, A/C SWITCH "ON" Signal TO ECM
WITH DIAGNOSTIC CHECK CONNECTOR SHORTED
- A/C SWITCH/circuit
- A/C AMPLIFIER
- TPS/CIRCUIT
- NEUTRAL START SWITCH/circuit
52 Knock Sensor signal
- OPEN OR SHORT IN KNOCK SENSOR Signal
- KNOCK SENSOR/circuit
53 Knock Control signal in ECM FAULTY or Engine control module (ECM) knock control – defective
(P1605)
54 Inter-cooler ECM signal
Intercooler coolant circulation capacity diminished (fail-safe operation: ignition timing program retarded by
2 degr.)
55 Knock Sensor signal
Open or short circuit in knock sensor signal (Chaser TRD with 2JZ-GTE)
56 Cooling Fan Pressure Sw.
58 SCVP, E2, SCV+, SCV (for –FSE)
59 VVT-i Valve - for FSE)
71 EGR System
EGR VALVE MALFUNCTION
- EXHAUST GAS TEMPEATURE BELOW SPEC. FOR EGR CONTROL
- EGR SYSTEM
- EGR GAS TEMPERATURE SENSOR circuit
72 Fuel Cut Solenoid signal
IGF SIGNAL IS DETECTED FOR 4 CONSECUTIVE IGNITIONS
72 A/C System (A/C Relay Open)
78 (Avensis) Fuel circuit - malfunction
78, 79 Fuel Pump Control signal (S+, E1 for FSE) (P1235
- Fuel Pump Control signal, P1200- Fuel Pump Relay/ECU Malfunction ?)
- Open or Short circuit in fuel Pump Control circuit or Fuel Pump Electronic Control Unit (ECU)
79 D-4
81 TCM Communication
- Open in ECT1 circuit between ECM & Transmission Control Module (TCM) for at Least 2 seconds
83 TCM Communication
- Open in ESA1 circuit between ECM & Transmission Control Module (TCM) for 1/2 second after engine
idles at least 1/2 second
84 TCM Communication
- Open in ESA2 circuit between ECM & Transmission Control Module (TCM) for 1/2 second after engine
85 TCM Communication
- Open in ESA3 circuit between ECM & Transmission Control Module (TCM) for 1/2 second after engine
89 (P1125, 1126, 1127, 1128) read a pulse ETCS-SNOW (Chaser TRD with 2JZ-GTE)
92 D-4 (p1210)
96 (p1600) Engine control module (ECM) -supply
97 D-4 (p1215) EDU Malfunction
97 (Avensis) Injector control module – circuit malfunction
98 D-4
99 (B2799) there is a trouble with immobilizer (for the OBDII-equiped Vechicle)
PostNapisane: 23 lut 2007, o 22:50
Pochwały: 56
Diagnostic Trouble Codes
body DTCs
B0100 Short In D Squib Circuit
B0101 Open in Driver-Side Air Bag Module Squib Circuit
B0102 Short in D Squib Circuit (to Ground)
B0103 Short in D Squib Circuit (to B+)
B0105 Short in P Side Air Bag Squib Circuit
B0106 Open In P Side Air Bag Squib Circuit
B0107 Short In P Side Air Bag Squib Circuit (to Ground)
B0108 Short In P Side Air Bag Squib Circuit (to B+)
B0110 Short In Side Squib (RH) Circuit
B0111 Open In Side Squib (RH) Circuit
B0111 Cab Side Airbag Circuit (Range/Performance) Malfunction ( AV.’99)
B0112 Short In Side Air Bag Module Squib (RH) Circuit (to Ground)
B0113 Short In Side Squib (RH) Circuit (to B+)
B0115 Short in Side Air Bag Module Squib (LH) Circuit
B0116 Open In Side Air Bag Module Squib (LH) Circuit
B0117 Short In Side Squib (LH) Circuit (to Ground)
B0118 Short In Side Air Bag Module Squib (LH) Circuit (to B+)
B0121 Seat Belt Buckle Swith, RH malfunction
B0122 Seat Belt Buckle Swith, RH malfunction
B0126 Seat Belt Buckle Swith, LH malfunction
B0127 Seat Belt Buckle Swith, LH malfunction
B0130 Short in P-Side Seat Belt Pretensioner Squib (RH) Circuit
B0131 Open in P-Side Seat Belt Pretensioner Squib (RH) Circuit
B0132 Short in P-Side Seat Belt Pretensioner Squib (RH) Circuit (to Ground)
B0133 Short in P-Side Seat Belt Pretensioner Squib (RH) Circuit (to B+)
B0135 Short in D-Side Seat Belt Pretensioner Squib (LH) Circuit
B0136 Open in D-Side Seat Belt Pretensioner Squib (LH) Circuit
B0137 Short in D-Side Seat Belt Pretensioner Squib (LH) Circuit (to Ground)
B0138 Short in D-Side Seat Belt Pretensioner Squib (LH) Circuit (to B+)
B1100 Airbag Sensor Assembly Malfunction (Progr. Avens)
B1135 SRS Control Module – poor multi-plug connection
B1140 Side Airbag Sensor Assembly (RH) Malfunction
B1141 Side Airbag Sensor Assembly (LH) Malfunction
B1142 Door Side Airbag Sensor (RH) Malfunction
B1143 Door Side Airbag Sensor (RH) Malfunction
B1144 Door Side Airbag Sensor (LH) Malfunction
B1145 Door Side Airbag Sensor (LH) Malfunction
B1146 Side Crach Sensor, RH B post Malfunction
B1147 Side Crach Sensor, LH B post Malfunction
B1148 Front Crach Sensor, RH Malfunction
B1149 Front Crach Sensor, LH Malfunction
B1153 Seat Position Sensor malfunction
B1154 Side Crach Sensor, Rear RH in C posts
B1155 Side Crach Sensor, Rear LH in C posts
B1156 Front Airbag (Front crach) Sensor (RH) Malfunction
B1157 Front Airbag (Front crach) Sensor (RH) Malfunction
B1158 Front Airbag (Front crach) Sensor (LH) Malfunction
B1159 Front Airbag Sensor (LH) Malfunction
B1160 Inflatable curtain RH short circuit
B1161 Inflatable curtain RH open circuit
B1162 Inflatable curtain RH short circuit to Earth
B1163 Inflatable curtain RH short circuit to Positive
B1165 Inflatable curtain LH short circuit
B1166 Inflatable curtain LH open circuit
B1167 Inflatable curtain LH short circuit to Earth
B1168 Inflatable curtain LH short circuit to Positive
B1180 Driver’s Air Bag, Stage 2 – short circuit
B1181 Driver’s Air Bag, Stage 2 – open circuit
B1182 Driver’s Air Bag, Stage 2 – – short circuit to Earth
B1183 Driver’s Air Bag, Stage 2 – short circuit tp Positive
B1185 Passenger Air Bag Stage 2 short circuit
B1186 Passenger Air Bag Stage 2 open circuit
B1187 Passenger Air Bag Stage 2 short circuit to Earth
B1188 Passenger Air Bag Stage 2 short circuit to Positive
B1211 No Communication Between Driver's Door ECU & Body ECU
B1212 No Communication Between Passenger's Front Door ECU & Body ECU
B1214 Door System Bus Communication Circuit is Shorted To Battery Voltage
B1215 Door System Bus Communication Circuit is Shorted To Ground
B1216 No Communication Between Right Rear Door ECU & Body ECU
B1217 No Communication Between Left Rear Door ECU & Body ECU
B1221 Power Window Master Switch Circuit
B1222 Driver's Door Lock Control Switch Circuit
B1223 Passenger's Front Window Switch Circuit
B1224 Passenger's Door Lock Control Switch Circuit
B1225 Right Rear Window Switch Circuit
B1226 Left Rear Window Switch Circuit
B1231 Driver's Jam Protection Limit Switch Circuit
B1232 Driver's Jam Protection Pulse Switch Circuit
B1233 Passenger's Front Jam Protection Limit Switch Circuit
B1234 Passenger's Front Jam Protection Pulse Switch Circuit
B1235 Right Rear Jam Protection Limit Switch Circuit
B1236 Right Rear Jam Protection Pulse Switch Circuit
B1237 Left Rear Jam Protection Limit Switch Circuit
B1238 Left Rear Jam Protection Pulse Switch Circuit
B1241 Body ECU Switch Circuit Diagnosis ONE OF MONITORED SWITCHES HAS ABNORMAL OUTPUT
B1242 Wireless Door Lock Tuner Circuit Malfunction (WIRELESS DOOR LOCK RECEIVER)
B1243 GSW TERMINAL CIRCUIT MALFUNCTION
B1244 Light Sensor Circuit Malfunction
B1251 MIRROR CONTROL SWITCH
B1256 Instrument Control Panel Circuit Diagnosis
B1261 No Communication Between ECM & Body ECU
B1269 THEFT DETERRENT ECU COMMUNICATION STOPPED
B1272 No Communication between Power Seat ECU (W/Memory) & Body ECU (POWER SEAT ECU
COMMUNICATION STOPPED)
B1273 No Communication Between Sun Roof Control ECU & Body ECU
B1275 No Communication Between Accessory Bus Buffer & Body ECU
B1276 No Communication Between Combination Meter ECU & Body ECU
B1277 No Communication Between Instrument Control Panel & Body ECU
B1300 Engine Coolant Temperature Sensor for Hydraulic Cooling Fan Circuit Malfunction
B1305 Solenoid for Hydraulic Cooling Fan Circuit Malfunction
B1421 Solar Sensor Circuit (Passenger Side) (Progr., RX3))
B1423 Open in pressure Sensor Circuit / Abnormal refrigerant Pressure (Progr, RX3)
B1424 Solar Sensor Circuit (Driver Side) (Progr.)
B2785 Ignition Switch ON Malfunction
B2786 Ignition Switch OFF Malfunction
B2790 Key Unlock Warning Switch ON Malfunction
B2791 Key Unlock Warning Switch Off Malfunction
B2795 Unmatched Key Code
B2796 No Communication in Immobiliser System
B2797 Communication Malfunction No.1
B2798 Communication Malfunction No.2
B2799 Engine Immobiliser System Malfunction
Pochwały: 56
chassis DTCs
C0200 FR Whell Speed Sensor Malfunction (Cald, Cam, RX3, Cel.)
C0205 FL Whell Speed Sensor Malfunction (Cald, Cel.)
C0210 RR Whell Speed Sensor Malfunction (Cald, Cam, Cel.)
C0215 LR Speed Sensor Circuit (Cel.)
C0226 ABS Actuator Solenoid Circuit (Cel.) or ABS Solenoid Valve Circuit (MR)
C0236 ABS Actuator Solenoid Circuit (MR, Cel.)
C0237 Speed Sensor Circuit (Cel.)
C0238 Speed Sensor Circuit (Cel.)
C0239 Speed Sensor Circuit (Cel.)
C0246 ABS Actuator Solenoid Circuit (MR, Cel.)
C0256 ABS Actuator Solenoid Circuit (MR, Cel.)
C0273 ABS Motor Relay Circuit (MR, Cel.)
C0274 ABS Motor Relay Circuit (MR, Cel.)
C0278 ABS Motor Relay Circuit (MR, Cel.)
C0279 ABS Motor Relay Circuit (MR, Cel.)
C0274 Water Pump Motor Relay Circuit Voltage to High (Cam.)
C0278 Solenoid Relay Circuit Voltage to Low (Cam.)
C0279 Solenoid Relay Circuit Voltage to High (Cam.)
C0371 VSC Sensor Signal or Circuit malfunction
C1200 Brake Boost Sensor Circuit Malfunction
C1201 Brake Boost Sensor Circuit Range/Performance
C1201 Engine Control System Malfunction (VCS lamp ON-RX3) or ECM/TCM malfunction
C1203 ECM/TRC communication Circuit malfunction (RX, LC)
C1207 Starter Signal block malfunction
C1208 Steering Position Sensor Signal or Circuit malfunction
C1210 No learned (adaptation) VSC Sensor
C1223 Malfunction in ABS Control System (RX3)
C1224 NEO Signal Circuit Open or Short
C1231 Steering Angle Sensor Signal or Circuit malfunction (Progr.)
C1232 Accel. Sensor Signal or Circuit malfunction
C1233 VSC Sensor Circuit Open or Short/33 or Yaw Sensor Circuit Open or Short (Progr., RX3)
C1234 VSC Sensor Signal Out of Range (malfunction)
C1235 Speed Sensor Rotor / Right Front (Cel.)
C1236 Speed Sensor Rotor / Left Front (Cel.)
C1336 No learned (adaptacion) VSC Sensor
C1238 Speed Sensor Circuit (MR), Speed Sensor Rotor / Right Rear (Cel.)
C1239 Speed Sensor Circuit (MR), Speed Sensor Rotor / Left Rear (Cel.)
C1340 Block Diff. Circuit malfunction/47?
C1241 IG Power Source Circuit (MR, Cel.)
C1244 Deceleration Sensor Circuit Open or Short (Progr.)
C1249 Brake Light Switch Circuit Malfunction (Cam., MR)
C1251 ABS Pump Motor Lock (MR, Cel.)
C1271 Low Output Voltage of Right Front Speed Sensor (MR)
C1272 Low Output Voltage of Left Front Speed Sensor (MR)
C1273 Low Output Voltage of Right Rear Speed Sensor (MR)
C1274 Low Output Voltage of Left Rear Speed Sensor (MR)
C1275 Abnormal Change in Input Voltage of Right Front Speed Sensor (MR)
C1276 Abnormal Change in Input Voltage of Left Front Speed Sensor (MR)
C1277 Abnormal Change in Input Voltage of Right Rear Speed Sensor (MR)
C1278 Abnormal Change in Input Voltage of Left Rear Speed Sensor (MR)
C1511 / C1514 Torque Sensor Circuit Malfunction
C1515 Calibration of torque sensor zero point Not Performed
C1516 Calibration of torque sensor zero point Not completed
C1521 Power Steering Motor Malfunction (MR2, Pri)
C1522 Power Steering Motor Malfunction (MR2, Pri)
C1523 Power Steering Motor Malfunction (MR2, Pri)
C1531 Power Steering ECU Malfunction (MR2, Pri)
C1539 Power Steering ECU Malfunction (MR2)
C1541 Speed sensor Malfunction (Pri)
C1571 IG power source circuit malfunction (Pri)
C1552 PIG Power Source Drop Voltage Malfunction (MR2, Pri)
C1553 When Resetting Voltage, Vehicle Is Being Driven (MR2, Pri)
C1554 EMPS relay circuit malfunction (Pri)
C1555 EMPS ECU malfunction (Pri)
C1556 P/S warning light circuit (Pri)
C1557 Memory of overheat prevention control (Pri)
C1558 Memory of voltage drop at motor power supply (Pri)
C1559 Memory of continuous control under high load (Pri)
C1571 Speed sensor malfunction (Test mode)
C1572 Speed Sensor Signal Malfunction (MR2)
C1782 Stop Switch Circuit Malfunction (LX47)
C1783 Door Courtesy Switch Circuit Malfunction (LX47)
C1786 Hight Control Switch Circuit Malfunction (LX47)
C1787 EMS Switch Circuit Malfunction (LX47)
C1788 Height Control OFF Switch Circuit Malfunction (LX47)
C1794 RH Front Weel Speed Sensor Circuit malfunction (LX47)
C1795 LH Front Weel Speed Sensor Circuit malfunction (LX47)
C2111 Tire pressure sensor ID1 operation stop
C2112 Tire pressure sensor ID2 operation stop
C2113 Tire pressure sensor ID3 operation stop
C2114 Tire pressure sensor ID4 operation stop
C2115 Tire pressure sensor ID5 operation stop
C2121 Tire pressure sensor ID1 not received
C2122 Tire pressure sensor ID2 not received
C2123 Tire pressure sensor ID3 not received
C2124 Tire pressure sensor ID4 not received
C2125 Tire pressure sensor ID5 not received
C2141 A malfunction in the tire pressure sensor registered to ID1
C2142 A malfunction in the tire pressure sensor registered to ID2
C2143 A malfunction in the tire pressure sensor registered to ID3
C2144 A malfunction in the tire pressure sensor registered to ID4
C2145 A malfunction in the tire pressure sensor registered to ID5
C2165 Abnormal temperature inside ID1 tire
C2166 Abnormal temperature inside ID2 tire
C2167 Abnormal temperature inside ID3 tire
C2168 Abnormal temperature inside ID4 tire
C2169 Abnormal temperature inside ID5 tire
C2171 Tire pressure sensor ID not registered
C2176 Tire pressure monitor receiver is error
C2181 Tire pressure sensor ID1 not received (test diagnosis)
C2182 Tire pressure sensor ID2 not received (test diagnosis)
C2183 Tire pressure sensor ID3 not received (test diagnosis)
C2184 Tire pressure sensor ID4 not received (test diagnosis)
C2185 Tire pressure sensor ID5 not received (test diagnosis)
C2191 Vehicle speed signal error (test diagnosis)
PostNapisane: 23 lut 2007, o 22:51
Pochwały: 56
powertrain DTCs
P0010 Camshaft Position “A” – Actuator Circuit (Bank 1) – Cor ‘04
P0011 Camshaft Position “A” – Timing Over-Advanced or System performance (Bank 1) – Cor ‘04
P0012 Camshaft Position “A” – Timing Over-Retarded (Bank 1) – Cor ‘04
P0016 Crankshaft Position-Camshaft Position Correlacion (Bank 1 Sensor A) – Cor ‘04
P0031 Oxygen Sensor Heater Control Circuit Low (Bank 1 Sensor 1) – Cor ‘04
P0032 Oxygen Sensor Heater Control Circuit High (Bank 1 Sensor 1) – Cor ‘04
P0100 Mass or Volume Air Flow Circuit Malfunction
P0101 Mass Air Flow Circuit Range/Performance Problem
P0102 Mass Air Flow Circuit Malfunction (Low Input – Cor “04)
P0103 Mass Air Flow Circuit Malfunction (High Input – Cor “04)
P0105 Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
P0106 Manifold Absolute Pressure Circuit Problem
P0110 Intake Air Temperature (IAT) Circuit Malfunction
P0112 Intake Air Temperature (IAT) Circuit Low Input – Cor ‘04
P0113 Intake Air Temperature (IAT) Circuit High Input – Cor ‘04
P0115 Engine Coolant Temperature Circuit Malfunction
P0116 Engine Coolant Temperature Circuit Range/Performance Problem (after Engine Operates at Least
20 Minutes, Engine Coolant Temp. Sensor Value is 86°F aka 30°C or less)
P0117 Engine Coolant Temperature Circuit Low Input
P0118 Engine Coolant Temperature Circuit High Input
P0120 Throttle/Pedal Position Sensor/Switch "A" Circuit Malfunction
P0121 Throttle/Pedal Position Sensor/Switch "A" Circuit Range/Performance Problem
P0122 Throttle/Pedal Position Sensor/Switch "A" Circuit Low Input – Cor ‘04
P0123 Throttle/Pedal Position Sensor/Switch "A" Circuit High Input – Cor ‘04
P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control
P0128 Thermostat Malfunction (Coolant Temperature below Thermostat Regulating Temperature)
P0130 O2 Sensor Circuit Malfunction (Bank 1 Sensor 1)
P0133 O2 Sensor Circuit Slow Response (Bank 1 Sensor 1)
P0134 Oxygen Sensor Circuit no activity Detected (Bank 1 Sensor 1) – Cor ‘04
P0135 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
P0136 O2 Sensor Circuit Malfunction (Bank 1 Sensor 2)
P0139 O2 Sensor Circuit Slow Response (Bank 1 Sensor 2)
P0141 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
P0142 O2 Sensor Circuit Malfunction (Bank 1 Sensor 3)
P0147 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 3)
P0150 O2 Sensor Circuit Malfunction (Bank 2 Sensor 1)
P0153 O2 Sensor Circuit Slow Response (Bank 2 Sensor 1)
P0155 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1) or Oxygen Sensor Heater Current is Less
than 0.25 amp, or Exceeds 2 amps or Voltage Drop for the Heater Exceeds 5 Volts (Cam.)
P0156 O2 Sensor Circuit Malfunction (Bank 2 Sensor 2)
P0159 O2 Sensor Circuit Slow Response (Bank 2 Sensor 2)
P0161 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)
P0162 O2 Sensor Circuit Malfunction (Bank 2 Sensor 3)
P0167 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 3)
P0170 Fuel Trim Malfunction
P0171 System too Lean (Fuel Trim) (tens cars)
P0172 System too Rich (Fuel Trim)
P0174 System too Lean (A/F Lean Malfunction, Bank2)
P0175 System too Rich (Bank2) 26
P0176 Fuel Composition Sensor Circuit Malfunction
P0180 Fuel Temperature Sensor "A" Circuit Malfunction
P0190 Fuel Rail Pressure Sensor Circuit Malfunction
P0191 Fuel Rail Pressure Sensor Circuit Range/Performance (Vist.)
P0200
P0201 Cylinder No. 1 Misfires Continuously
P0202 Cylinder No. 2 Misfires Continuously
P0203 Cylinder No. 3 Misfires Continuously
P0204 Cylinder No. 4 Misfires Continuously
P0205 Cylinder No. 5 Misfires Continuously
P0206 Cylinder No. 6 Misfires Continuously
P0300 Random/Multiple Cylinder Misfire Detected or Misfiring Of Multiple Cylinders During Same 200-1000 Engine Revolutions
P0301 Cylinder 1 Misfire Detected
P0302 Cylinder 2 Misfire Detected
P0303 Cylinder 3 Misfire Detected
P0304 Cylinder 4 Misfire Detected
P0305 Cylinder 5 Misfire Detected
P0306 Cylinder 6 Misfire Detected
P0307 Cylinder 7 Misfire Detected
P0308 Cylinder 8 Misfire Detected
P0309 Cylinder 9 Misfire Detected
P0310 Cylinder 10 Misfire Detected
P0311 Cylinder 11 Misfire Detected
P0312 Cylinder 12 Misfire Detected
P0325 Knock Sensor 1 Circuit Malfunction (Bank 1 or Single Sensor on Cor ’04)
P0327 Knock Sensor 1 Circuit Low Input (Bank 1 or Single Sensor) - Cor ’04)
P0328 Knock Sensor 1 Circuit High Input (Bank 1 or Single Sensor) - Cor ’04)
P0330 Knock Sensor 2 Circuit Malfunction (Bank 2)
P0335 Crankshaft Position Sensor "A" Circuit Malfunction
P0336 Crankshaft Position Sensor "A" Circuit Range/Performance or Deviation in Crankshaft & Camshaft
Position Sensor Signals (Cam.)
P0339 Crankshaft Position Sensor "A" Circuit Intermittet – Cor ‘04
P0340 Camshaft Position Sensor Circuit Malfunction (Mar.,Cam. Cor ‘04)
P0341 Camshaft Position Sensor Circuit Range/Performance (Bank 1 or Single Sensor) – Cor ‘04
P0351 Ignition Coil “A” Primary/Secondary Circuit – Cor ‘04
P0352 Ignition Coil “B” Primary/Secondary Circuit – Cor ‘04
P0353 Ignition Coil “C” Primary/Secondary Circuit – Cor ‘04
P0354 Ignition Coil “D” Primary/Secondary Circuit – Cor ‘04
P0385 Crankshaft Position Sensor "B" Circuit Malfunction
P0400 Exhaust Gas Recirculation Flow Malfunction
P0401 Exhaust Gas Recirculation Flow Insufficient Detected With Engine Warm & Driven at 50 MPH for 3-5 Minutes, EGR Gas Sensor Value does Not Exceed Ambient Air Temperature By 72°F aka 40°C
(Cam.)
P0402 Exhaust Gas Recirculation Flow Excessive Detected
P0403 Exhaust Gas Recirculation Circuit Malfunction
P0410 Secondary Air Infection System Malfunction
P0411 Secondary Air Injection System Incorrect Flow Detected.
P0412 Secondary Air Infection System Switching Valve "A" Circuit Malfunction
P0420 Catalyst System Efficiency Below Threshold (Bank 1) - With Engine Warm & Driven at 20-50 MPH
for 5 Minutes, Heated Oxygen Sensors Have Same Wave Patterns (Cam.)
P0430 Catalyst System Efficiency Below Threshold (Bank 2)
P0440 Evaporative Emission Control System Malfunction
P0441 Evaporative Emission Control System Incorrect Purge Flow
P0442 Evaporative Emission Control System Leak Detected (Small Leak)
P0443 Evaporative Emission Control System Purge Control Valve Circuit Malfunction
P0446 Evaporative Emission Control System Vent Control Malfunction
P0450 Evaporative Emission Control System Pressure Sensor Malfunction
P0451 Evaporative Emission Control System Pressure Sensor Range/Performance
P0452 Evaporative Emission Control System Pressure Sensor Low Input – Cor ‘04
P0453 Evaporative Emission Control System Pressure Sensor High Input – Cor ‘04
P0456 Evaporative Emission Control System Leak Detected (Very Small Leak)
P0500 Vehicle Speed Sensor Malfunction
P0505 Idle Control System Malfunction or Idle Speed Varies Greatly from ECM Target Speed
P0510 Closed Throttle Position Switch Malfunction
P0511 Idle Air Control Circuit – Cor ‘04
P0550 Power Steering Pressure Sensor Circuit Malfunction or Closed Throttle Position Switch Does Not
Turn On when Vehicle is Driven
P0560 System Voltage – Cor ‘04
P0605 Internal Control Module Read Only Memory (ROM) Error
P0606 ECM/PCM Processor
P0617 Starter Relay Circuit High – Cor ‘04
P0705 Transmission Range Sensor Circuit Malfunction (PRNDL Input) - Cor ‘04
P0710 Transmission Fluid Temperature Sensor Circuit malfunction
P0711 Transmission Fluid Temperature Sensor Circuit Range / Performance
P0715 Input/Turbine Speed Sensor Circuit Malfunction (Mar.)
P0724 Brake Switch “B” Circuit High – Cor ‘04
P0725 Engine Speed Input Circuit Malfunction
P0740 ECT ECU Malfunction
P0741 Totque Converter Clutch Solenoid Performance (Shift Solenoid Valve SL) - Cor ‘04
P0750 Shift Solenoid "A" (SL1) Malfunction or Shift Solenoid A/B Malfunction
P0751 Shift Solenoid “A” perfgormance (Shift Solenoid Valve S1) - Cor ‘04
P0753 Shift Solenoid "A" (SL1) Electrical Malfunction
P0755 Shift Solenoid "B" (SL2) Malfunction or During Normal Driving, Gear Required By ECM Does Not
Match Actual Gear (Cam.)
P0756 Shift Solenoid “B” perfgormance (Shift Solenoid Valve S2) - Cor ‘04
P0758 Shift Solenoid "B" (SL2) Electrical Malfunction
P0760 Shift Solenoid "C" Malfunction
P0763 Shift Solenoid "C" Electrical
P0765 Shift Solenoid "D" (S4 or Shift Solenoid Valve No. 4) Malfunction
P0768 Shift Solenoid "D" (S4 or Shift Solenoid Valve No. 4) Electrical
P0770 Shift Solenoid "E" (Lock-Up Solenoid, also called SL solenoid) Malfunction
P0773 Shift Solenoid "E" (Lock-Up Solenoid) Electrical Circuit Malfunction
P0850 Park/Neutral Switch Input Circuit – Cor ‘04
P0973 Shift Solenoid “A” control Citcuit Low (Shift Solenoid Valve S1) - Cor ‘04
P0974 Shift Solenoid “A” control Citcuit High (Shift Solenoid Valve S1) - Cor ‘04
P0976 Shift Solenoid “B” control Citcuit Low (Shift Solenoid Valve S2) - Cor ‘04
P0977 Shift Solenoid “B” control Citcuit High (Shift Solenoid Valve S2) - Cor ‘04
P1100 Atmospheric Press Sensor Malfunction
P1101 Atmospheric Press Sensor Circuit Range / Performance
P1105 Combustion Press Sensor Malfunction
P1120 Accelerator Pedal Position Sensor Circuit Malfunction
P1121 Accelerator Pedal Position Sensor Range/Performance Problem
P1125 Throttle Control Motor Circuit Malfunction
P1126 Magnetic Clutch Circuit Malfunction
P1127 ETCS Actuator Power Source Circuit Malfunction
P1128 Throttle Control Motor Lock Malfunction
P1129 Electric Throttle Control System Malfunction
P1130 A/F Sensor Circuit Range/Performance Malfunction (Bank 1 Sensor 1)
P1133 20 A/F Sensor Circuit Response Malfunction (Bank 1 Sensor 1)
P1135 A/F Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
P1136 A/F Sensor Circuit Malfunction (Bank 1 Sensor 2)
P1139 A/F Sensor Circuit Slow Response (Bank 1 Sensor 2)
P1141 A/F Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
P1150 A/F Sensor Circuit Range/Performance Malfunction (Bank 2 Sensor 1)
P1153 A/F Sensor Circuit Response Malfunction (Bank 2 Sensor 1)
P1155 A/F Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
P1156 A/F Sensor Circuit Malfunction (Bank 2 Sensor 2)
P1159 A/F Sensor Circuit Slow Response (Bank 2 Sensor 2)
P1161 A/F Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)
P1180 CNG Pressure Sensor Circuit Malfunction
P1185 CNG Temperature Sensor Circuit Malfunction
P1190 Fuel Pressure Regulator Malfunction
P1200 Fuel Pump Relay/ECU Circuit Malfunction
P1205 Electric Air Pump Circuit Malfunction.
P1210 Injector Control Pressure Above Expected Level
P1215 EDU Circuit Malfunction (Ath.)
P1220 Timer Control Circuit Malfunction
P1221 Venturi Control Circuit Malfunction
P1225 Spill Control Circuit Malfunction
P1230 Venturi Position Sensor Malfunction
P1235 High Pressure Fuel Pump Circuit Malfunction or “Fuel Pump Control Out Of Range”
P1240 Fuel Shutoff Valve Circuit for Delivery Pipe Malfunction
P1245 Fuel Shutoff Valve Circuit for Pressure Regulator Malfunction
P1300 Igniter Circuit Malfunction
P1305 Igniter No. 2 Circuit Malfunction
P1310 Igniter No. 3 Circuit Malfunction
P1315 Igniter No. 4 Circuit Malfunction
P1320 Igniter No. 5 Circuit Malfunction
P1325 Igniter No. 6 Circuit Malfunction
P1330 Igniter No. 7 Circuit Malfunction
P1335 Crankshaft Position Sensor (CKP) Circuit Malfunction (During engine running) (Vist., Cam.)
P1340 Igniter No. 8 Circuit Malfunction (1998-2000 Land Cruiser & 2000 Tundra)
P1345 VVT (Variable Valve Timing) Sensor/Camshaft Position Sensor Circ. Malfunction (Bank1)
P1346 VVT (Variable Valve Timing) Sensor/Camshaft Position Sensor Circuit Range/Performance Problem (Bank 1)
P1349 VVT (Variable Valve Timing) System Malfunction (Bank 1)
P1350 VVT (Variable Valve Timing) Sensor/Camshaft Position Sensor Circ. Malfunction (Bank2)
P1351 VVT (Variable Valve Timing) Sensor/Camshaft Position Sensor Circuit Range/Performance Problem (Bank 2)
P1354 VVT (Variable Valve Timing) System Malfunction (Bank 2)
P1357 Exhaust VVT Sensor/Camshaft Position Sensor Circuit Malfunction (Bank 1)
P1358 Exhaust VVT Sensor/Camshaft Position Sensor Circuit Malfunction (Bank 2)
P1360 Exhaust VVT Sensor/Camshaft Position Sensor Circuit Malfunction (Bank 1)
P1365 Exhaust VVT Sensor/Camshaft Position Sensor Circuit Malfunction (Bank 2)
P1400 Sub Throttle Position Sensor Circuit Malfunction
P1401 Sub Throttle Position Sensor Circuit Range/Performance Problem
P1405 Turbo Pressure Sensor Circuit Malfunction
P1406 Turbo Pressure Sensor Circuit Range/Performance Problem
P1410 EGR Valve Position Sensor Circuit Malfunction
P1411 EGR Valve Position Sensor Circuit Range/Performance Problem
P1415 Air Pump Circuit Malfunction/ (AIR) System Bank 1
P1416 Port Air Circuit Malfunction/ (AIR) System Bank 2
P1420 Intake Constrictor CTRL Circuit Open or Short
P1430 Vacuum Sensor for HC Adsorber and Catalyst (HCAC) System Circuit Malfunction (HV)
P1431 Vacuum Sensor for HC Adsorber and Catalyst (HCAC) System Circuit Range/Performance Problem
P1436 23 Toyota-HCAC-System By-Pass Value Impromevent-Open Malfunction (Pri)
P1437 Toyota-HCAC-System By-Pass Valve Close Malfunction
P1437 Vacuum Line Malfunction (HV)
P1455 Vapor Reducing Fuel Tank System Malfunction
P1455 Vapor Reducing Fuel Tank System Leak Detected (Small Leak) (HV)
P1500 Starter Signal Circuit Malfunction
P1505 Switch Signal Malfunction
P1510 Boost Pressure Control Malfunction
P1511 Boost Pressure Low Malfunction
P1512 Boost Pressure High Malfunction
P1515 Inter Cooler System Malfunction
P1520 Stop Light Switch Circuit Malfunction (A/T)
P1525 Resolver Circuit Malfunction
P1565 Cruise Control Main Switch Circuit Malfunction
P1566 Input Signal Circuit Abnormal or Cruise Control Main Switch Circuit Fault
P1600 ECM BATT Malfunction
P1605 Knock Control CPU Malfunction
P1610 Combustion Control CPU Malfunction
P1620 ECT1 Signal Circuit Malfunction
P1625 ESA1 Signal Circuit Malfunction
P1626 ESA2 Signal Circuit Malfunction
P1627 ESA3 Signal Circuit Malfunction
P1630 Traction Control System Malfunction
P1633 ECM Malfunction (ETCS Circuit) or Electronic Throttle Control System (ETCS) Circuit ECM
Malfunction
P1636 HV ECU Malfunction
P1637 E(G?)STP signal Malfunction (ESTP Signal Malfunction – Pri)
P1645 Body ECU Malfunction
P1650 Fuel Pressure Up VSV Circuit Malfunction
P1651 VSV For ACIS Circuit Malfunction
P1652 IACV Control Circuit Malfunction
P1653 SCV Circuit Malfunction
P1654 Idle Up VSV Circuit Malfunction
P1655 Idle Purge VSV Circuit Malfunction
P1656 OCV (Oil Control Valve) Circuit Malfunction (Bank 1)
P1657 Purge Cut VSV Circuit Malfunction
P1658 Waste Gate Valve Control Circuit Malfunction
P1659 Super Charger Control Circuit Malfunction
P1660 Air Bleed Control Circuit Malfunction
P1661 Exhaust Gas Control Valve Control Circuit Malfunction
P1662 Exhaust Bypass Valve Control Circuit Malfunction
P1663 OCV (Oil Control Valve) Circuit Malfunction (Bank 2)
P1666 Intake Air Control VSV No.2 Circuit Malfunction
P1667 TCV Circuit Malfunction
P1668 VSV for AICV Circuit Malfunction
P1690 OCV For VVTL Circuit Malfunction (Bank 1)
P1692 OCV For VVTL Open Malfunction (Bank 1)
P1693 OCV For VVTL Close Malfunction (Bank 1)
P1695 OCV For VVTL Circuit Malfunction (Bank 2)
P1697 OCV For VVTL Open Malfunction (Bank 2)
P1698 OCV For VVTL Close Malfunction (Bank 2)
P1700 Speed Sensor No.2 Malfunction
P1705 NC2 (Direct Clutch Speed Sensor) Revolution Sensor Circuit malfunction or Direct Clutch Speed
Sensor Output is 300 RPM or less with Vehicle at 20 MPH or more & with Park/Neutral Position
Switch Off
P1710 Steering Sensor Circuit Malfunction
P1715 Rear Wheel Sensor Circuit Malfunction
P1720 DC Clutch Forced Release Circuit Malfunction
P1725 NT Revolution Sensor or Input Turbine Speed Sensor Circuit Malfunction
P1730 NC Revolution Sensor Circuit Malfunction or Counter Gear Speed Sensor Circuit Fault
P1735 Right Front Speed Sensor Circuit Malfunction
P1740 Left Front Speed Sensor Circuit Malfunction
P1745 Transmission Fluid Temperature Sensor No.2 Circuit Malfunction
P1753 Shift Solenoid No.4 Circuit Malfunction
P1755 Linear Solenoid for Lock Up Ctrl Circ. Malfunction
P1760 Linear Solenoid for Line Pressure Control Circuit Malfunction or Shift Solenoid Valve SLT Fault or
Linear Solenoid for Lock-Up Control Circuit Malfunction
P1765 Linear Solenoid for Accumulator Pressure Control Circuit Malfunction (Shift Solenoid Valve “SLN”
malfunction) or with Engine Warm, Current Flow to Shift Solenoid Valve “SLN” is 0.2 Amp or less
for One Second with Engine at 500 RPM or more, or with Park/Neutral Position Switch Off
P1770 Deferential Lock Solenoid No.1 Circuit Malfunction
P1775 Deferential Lock Solenoid No.2 Circuit Malfunction
P1780 Park/Neutral Position (PNP) Switch malfunction (A/T only)
P1782 Transfer L4 SW Circuit Malfunction
P1783 Transfer N SW Circuit Malfunction
P1785 Auto Clutch System Malfunction
P1790 ST Solenoid (Shift solenoid valve ST) Circuit Malfunction
P1793 Shift Solenoid ST Circuit Malfunction
P1800 Automatic Transmission Operation Circuit Malfunction
P1805 Communication (between EFI ECU and Transmission ECU) Circuit Malfunction
P1810 Communication for Torque Control Circuit Malfunction
P1820 NIN Sensor Circuit Malfunction
P1825 NOUT Sensor Circuit Malfunction
P1845 PTO Sensor Circuit Malfunction
P1885 SLS Circuit Malfunction
P1888 SLS Circuit Malfunction
P1890 SLC Circuit Malfunction
P1891 SLC Circuit Malfunction
P1895 DSU Circuit Malfunction
P2195 Oxygen Sensor Signal Stuck Lean (Bank 1 Sensor 1) – Cor ‘04
P2196 Oxygen Sensor Signal Stuck Rich (Bank 1 Sensor 1) – Cor ‘04
P2716 Pressure Control Solenoid “D” Electrical (Shift Solenoid Valve SLT) - Cor ‘04
P2769 Torque Converter Clutch Solenoid Circuit Low (Shift Solenoid Valve SL) – Cor ‘04
P2770 Torque Converter Clutch Solenoid Circuit High (Shift Solenoid Valve SL) - Cor ‘04
P3000 HV Battery Malfunction
P3001 Battery ECU malfunction
P3002 HV ECU communication malfunction
P3004 Power Cable Malfunction
P3005 High voltage fuse snapped
P3006 Battery SOC are uneven
P3009 Leak detected (Electric leak from high–voltage system)
P3010 Battery total resistance malfunction
P3011 to P3029 Battery block malfunction
P3030 Battery voltage detective line snapped
P3060 Battery temperature sensor circuit malfunction
P3076 Abnormal air flow by battery cooling fan
P3077 Battery cooling fan motor circuit malfunction
P3100 HV ECU Malfunction
P3101 Engine System Malfunction
P3105 Battery ECU Communication Circuit Malfunction
P3106 ECM Communication Circuit Malfunction
P3107 Airbag ECU Communication Circuit Malfunction
P3108 A/C Amplifier Communication Circuit Malfunction
P3109 32 Brake ECU Communication Circuit Malfunction
P3110 IGCT relay is always closed
P3115 HV battery current sensor malfunction
P3115 System Main Relay Malfunction
P3120 HV Transaxle Malfunction
P3125 Converter & Inverter Assembly Malfunction
P3130 Inverter Cooling System Malfunction
P3135 Circuit Breaker Sensor Malfunction
P3140 Interlock Malfunction
P3145 Vehicle Speed Sensor Circuit Malfunction
P3190 Poor Engine Power (Pri)
P3191 Engine does not start (Pri)
PostNapisane: 5 sty 2012, o 20:29
Wygrzebałem, żeby w razie czego było łatwiej znaleźć.
Plusik.
PostNapisane: 2 paź 2012, o 21:46
KOD dec KOD hex Opis
B0100 B0064 Poduszka powietrzna kierowcy - usterka
B0101 B0065 Poduszka powietrzna kierowcy - sygnał poza zakresem/wydajność
B0102 B0066 Poduszka powietrzna kierowcy - niski sygnał wejściowy
B0103 B0067 Poduszka powietrzna kierowcy - wysoki sygnał wejściowy
B0105 B0069 Poduszka powietrzna pasażera - usterka
B0106 B006A Poduszka powietrzna pasażera - sygnał poza zakresem/wydajność
B0107 B006B Poduszka powietrzna pasażera - niski sygnał wejściowy
B0108 B006C Poduszka powietrzna pasażera - wysoki sygnał wejściowy
B0110 B006E Boczna poduszka powietrzna kierowcy - usterka
B0111 B006F Boczna poduszka powietrzna kierowcy - sygnał poza zakresem/wydajność
B0112 B0070 Boczna poduszka powietrzna kierowcy - niski sygnał wejściowy
B0113 B0071 Boczna poduszka powietrzna kierowcy - wysoki sygnał wejściowy
B0115 B0073 Boczna poduszka powietrzna pasażera - usterka
B0116 B0074 Boczna poduszka powietrzna pasażera - sygnał poza zakresem/wydajność
B0117 B0075 Boczna poduszka powietrzna pasażera - niski sygnał wejściowy
B0118 B0076 Boczna poduszka powietrzna pasażera - wysoki sygnał wejściowy
B0120 B0078 Obwód kontrolny przełącznika pasa bezpieczeństwa #1 - usterka
B0121 B0079 Obwód kontrolny przełącznika pasa bezpieczeństwa #1 - sygnał poza zakresem/wydajność
B0122 B007A Obwód kontrolny przełącznika pasa bezpieczeństwa #1 - niski sygnał wejściowy
B0123 B007B Obwód kontrolny przełącznika pasa bezpieczeństwa #1 - wysoki sygnał wejściowy
B0125 B007D Obwód kontrolny przełącznika pasa bezpieczeństwa #2 - usterka
B0126 B007E Obwód kontrolny przełącznika pasa bezpieczeństwa #2 - sygnał poza zakresem/wydajność
B0127 B007F Obwód kontrolny przełącznika pasa bezpieczeństwa #2 - niski sygnał wejściowy
B0128 B0080 Obwód kontrolny przełącznika pasa bezpieczeństwa #2 - wysoki sygnał wejściowy
B0130 B0082 Obwód powrotu pasa bezpieczeństwa #1 - usterka
B0131 B0083 Obwód powrotu pasa bezpieczeństwa #1 - sygnał poza zakresem/wydajność
B0132 B0084 Obwód powrotu pasa bezpieczeństwa #1 - niski sygnał wejściowy
B0133 B0085 Obwód powrotu pasa bezpieczeństwa #1 - wysoki sygnał wejściowy
B0135 B0087 Obwód powrotu pasa bezpieczeństwa #2 - usterka
B0136 B0088 Obwód powrotu pasa bezpieczeństwa #2 - sygnał poza zakresem/wydajność
B0137 B0089 Obwód powrotu pasa bezpieczeństwa #2 - niski sygnał wejściowy
B0138 B008A Obwód powrotu pasa bezpieczeństwa #2 - wysoki sygnał wejściowy
B0300 B012C Obwód wentylatora chłodzącego #1 - usterka
B0301 B012D Obwód wentylatora chłodzącego #1 - sygnał poza zakresem/wydajność
B0302 B012E Obwód wentylatora chłodzącego #1 - niski sygnał wejściowy
B0303 B012F Obwód wentylatora chłodzącego #1 - wysoki sygnał wejściowy
B0305 B0131 Obwód wentylatora chłodzącego #2 - usterka
B0306 B0132 Obwód wentylatora chłodzącego #2 - sygnał poza zakresem/wydajność
B0307 B0133 Obwód wentylatora chłodzącego #2 - niski sygnał wejściowy
B0308 B0134 Obwód wentylatora chłodzącego #2 - wysoki sygnał wejściowy
B0310 B0136 Obwód sprzęgła klimatyzacji (A/C) - usterka
B0311 B0137 Obwód sprzęgła klimatyzacji (A/C) - sygnał poza zakresem/wydajność
B0312 B0138 Obwód sprzęgła klimatyzacji (A/C) - niski sygnał wejściowy
B0313 B0139 Obwód sprzęgła klimatyzacji (A/C) - wysoki sygnał wejściowy
B0315 B013B Obwód ciśnienia #1 klimatyzacji (A/C) - usterka
B0316 B013C Obwód ciśnienia #1 klimatyzacji (A/C) - sygnał poza zakresem/wydajność
B0317 B013D Obwód ciśnienia #1 klimatyzacji (A/C) - niski sygnał wejściowy
B0318 B013E Obwód ciśnienia #1 klimatyzacji (A/C) - wysoki sygnał wejściowy
B0320 B0140 Obwód ciśnienia #2 klimatyzacji (A/C) - usterka
B0321 B0141 Obwód ciśnienia #2 klimatyzacji (A/C) - sygnał poza zakresem/wydajność
B0322 B0142 Obwód ciśnienia #2 klimatyzacji (A/C) - niski sygnał wejściowy
B0323 B0143 Obwód ciśnienia #2 klimatyzacji (A/C) - wysoki sygnał wejściowy
B0325 B0145 Sygnał wzorcowy ciśnienia klimatyzacji (A/C) - usterka
B0326 B0146 Sygnał wzorcowy ciśnienia klimatyzacji (A/C) - sygnał poza zakresem/wydajność
B0327 B0147 Sygnał wzorcowy ciśnienia klimatyzacji (A/C) - niski sygnał wejściowy
B0328 B0148 Sygnał wzorcowy ciśnienia klimatyzacji (A/C) - wysoki sygnał wejściowy
B0330 B014A Czujnik temp. powietrza zewnętrznego - usterka
B0331 B014B Czujnik temp. powietrza zewnętrznego - sygnał poza zakresem/wydajność
B0332 B014C Czujnik temp. powietrza zewnętrznego - niski sygnał wejściowy
B0333 B014D Czujnik temp. powietrza zewnętrznego - wysoki sygnał wejściowy
B0335 B014F Czujnik #1 temp. powietrza wewnętrznego - usterka
B0336 B0150 Czujnik #1 temp. powietrza wewnętrznego - sygnał poza zakresem/wydajność
B0337 B0151 Czujnik #1 temp. powietrza wewnętrznego - niski sygnał wejściowy
B0338 B0152 Czujnik #1 temp. powietrza wewnętrznego - wysoki sygnał wejściowy
B0340 B0154 Czujnik #2 temp. powietrza wewnętrznego - usterka
B0341 B0155 Czujnik #2 temp. powietrza wewnętrznego - sygnał poza zakresem/wydajność
B0342 B0156 Czujnik #2 temp. powietrza wewnętrznego - niski sygnał wejściowy
B0343 B0157 Czujnik #2 temp. powietrza wewnętrznego - wysoki sygnał wejściowy
B0345 B0159 Czujnik #1 ładowania słonecznego - usterka
B0346 B015A Czujnik #1 ładowania słonecznego - sygnał poza zakresem/wydajność
B0347 B015B Czujnik #1 ładowania słonecznego - niski sygnał wejściowy
B0348 B015C Czujnik #1 ładowania słonecznego - wysoki sygnał wejściowy
B0350 B015E Czujnik #2 ładowania słonecznego - usterka
B0351 B015F Czujnik #2 ładowania słonecznego - sygnał poza zakresem/wydajność
B0352 B0160 Czujnik #2 ładowania słonecznego - niski sygnał wejściowy
B0353 B0161 Czujnik #2 ładowania słonecznego - wysoki sygnał wejściowy
B0355 B0163 Silnik dmuchawy #1, obwód prędkości - usterka
B0356 B0164 Silnik dmuchawy #1, obwód prędkości - sygnał poza zakresem/wydajność
B0357 B0165 Silnik dmuchawy #1, obwód prędkości - niski sygnał wejściowy
B0358 B0166 Silnik dmuchawy #1, obwód prędkości - wysoki sygnał wejściowy
B0360 B0168 Silnik dmuchawy #1, obwód zasilania - usterka
B0361 B0169 Silnik dmuchawy #1, obwód zasilania - sygnał poza zakresem/wydajność
B0362 B016A Silnik dmuchawy #1, obwód zasilania - niski sygnał wejściowy
B0363 B016B Silnik dmuchawy #1, obwód zasilania - wysoki sygnał wejściowy
B0365 B016D Silnik dmuchawy #1, obwód masy - usterka
B0366 B016E Silnik dmuchawy #1, obwód masy - sygnał poza zakresem/wydajność
B0367 B016F Silnik dmuchawy #1, obwód masy - niski sygnał wejściowy
B0368 B0170 Silnik dmuchawy #1, obwód masy - wysoki sygnał wejściowy
B0370 B0172 Czujnik temp. po wysokiej stronie klimatyzacji (A/C) - usterka
B0371 B0173 Czujnik temp. po wysokiej stronie klimatyzacji (A/C) - sygnał poza zakresem/wydajność
B0372 B0174 Czujnik temp. po wysokiej stronie klimatyzacji (A/C) - niski sygnał wejściowy
B0373 B0175 Czujnik temp. po wysokiej stronie klimatyzacji (A/C) - wysoki sygnał wejściowy
B0375 B0177 Czujnik temp. wlotu parownika klimatyzacji (A/C) - usterka
B0376 B0178 Czujnik temp. wlotu parownika klimatyzacji (A/C) - sygnał poza zakresem/wydajność
B0377 B0179 Czujnik temp. wlotu parownika klimatyzacji (A/C) - niski sygnał wejściowy
B0378 B017A Czujnik temp. wlotu parownika klimatyzacji (A/C) - wysoki sygnał wejściowy
B0380 B017C Klimatyzacja (A/C) - podciśnienie czynnika chłodzącego
B0381 B017D Klimatyzacja (A/C) - nadciśnienie czynnika chłodzącego
B0400 B0190 Kontrola przepływu powietrza #1 - odszraniacz - usterka
B0401 B0191 Kontrola przepływu powietrza #1 - odszraniacz - sygnał poza zakresem/wydajność
B0402 B0192 Kontrola przepływu powietrza #1 - odszraniacz - niski sygnał wejściowy
B0403 B0193 Kontrola przepływu powietrza #1 - odszraniacz - wysoki sygnał wejściowy
B0405 B0195 Kontrola przepływu powietrza #2 - podgrzewacz - usterka
B0406 B0196 Kontrola przepływu powietrza #2 - podgrzewacz - sygnał poza zakresem/wydajność
B0407 B0197 Kontrola przepływu powietrza #2 - podgrzewacz - niski sygnał wejściowy
B0408 B0198 Kontrola przepływu powietrza #2 - podgrzewacz - wysoki sygnał wejściowy
B0410 B019A Kontrola przepływu powietrza #3 - (blend) - usterka
B0411 B019B Kontrola przepływu powietrza #3 - (blend) - sygnał poza zakresem/wydajność
B0412 B019C Kontrola przepływu powietrza #3 - (blend) - niski sygnał wejściowy
B0413 B019D Kontrola przepływu powietrza #3 - (blend) - wysoki sygnał wejściowy
B0415 B019F Kontrola przepływu powietrza #4 - odpowietrznik - usterka
B0416 B01A0 Kontrola przepływu powietrza #4 - odpowietrznik - sygnał poza zakresem/wydajność
B0417 B01A1 Kontrola przepływu powietrza #4 - odpowietrznik - niskie wejście
B0418 B01A2 Kontrola przepływu powietrza #4 - odpowietrznik - wysokie wejście
B0420 B01A4 Kontrola przepływu powietrza #5 - A/C - usterka
B0421 B01A5 Kontrola przepływu powietrza #5 - A/C - sygnał poza zakresem/wydajność
B0422 B01A6 Kontrola przepływu powietrza #5 - A/C - niski sygnał wejściowy
B0423 B01A7 Kontrola przepływu powietrza #5 - A/C - wysoki sygnał wejściowy
B0425 B01A9 Kontrola przepływu powietrza #6 - recyrkulacja - usterka
B0426 B01AA Kontrola przepływu powietrza #6 - recyrkulacja - sygnał poza zakresem/wydajność
B0427 B01AB Kontrola przepływu powietrza #6 - recyrkulacja - niski sygnał wejściowy
B0428 B01AC Kontrola przepływu powietrza #6 - recyrkulacja - wysoki sygnał wejściowy
B0430 B01AE Obwód odszraniania tylnej szyby - usterka
B0431 B01AF Obwód odszraniania tylnej szyby - sygnał poza zakresem/wydajność
B0432 B01B0 Obwód odszraniania tylnej szyby - niski sygnał wejściowy
B0433 B01B1 Obwód odszraniania tylnej szyby - wysoki sygnał wejściowy
B0435 B01B3 Obwód ustawienia klimatyzacji (A/C) - usterka
B0436 B01B4 Obwód ustawienia klimatyzacji (A/C) - sygnał poza zakresem/wydajność
B0437 B01B5 Obwód ustawienia klimatyzacji (A/C) - niski sygnał wejściowy
B0438 B01B6 Obwód ustawienia klimatyzacji (A/C) - wysoki sygnał wejściowy
B0440 B01B8 Obwód sprzężenia zwrotnego sterowania głowicy #1 - usterka
B0441 B01B9 Obwód sprzężenia zwrotnego sterowania głowicy #1 - sygnał poza zakresem/wydajność
B0442 B01BA Obwód sprzężenia zwrotnego sterowania głowicy #1 - niski sygnał wejściowy
B0443 B01BB Obwód sprzężenia zwrotnego sterowania głowicy #1 - wysoki sygnał wejściowy
B0445 B01BD Obwód sprzężenia zwrotnego sterowania głowicy #2 - usterka
B0446 B01BE Obwód sprzężenia zwrotnego sterowania głowicy #2 - sygnał poza zakresem/wydajność
B0447 B01BF Obwód sprzężenia zwrotnego sterowania głowicy #2 - niski sygnał wejściowy
B0448 B01C0 Obwód sprzężenia zwrotnego sterowania głowicy #2 - wysoki sygnał wejściowy
B0500 B01F4 Kierunkowskaz prawy - usterka
B0501 B01F5 Kierunkowskaz prawy - sygnał poza zakresem/wydajność
B0502 B01F6 Kierunkowskaz prawy - niski sygnał wejściowy
B0503 B01F7 Kierunkowskaz prawy - wysoki sygnał wejściowy
B0505 B01F9 Kierunkowskaz lewy - usterka
B0506 B01FA Kierunkowskaz lewy - sygnał poza zakresem/wydajność
B0507 B01FB Kierunkowskaz lewy - niski sygnał wejściowy
B0508 B01FC Kierunkowskaz lewy - wysoki sygnał wejściowy
B0510 B01FE Wskaźniki świateł przednich - usterka
B0511 B01FF Wskaźniki świateł przednich - sygnał poza zakresem/wydajność
B0512 B0200 Wskaźniki świateł przednich - niski sygnał wejściowy
B0513 B0201 Wskaźniki świateł przednich - wysoki sygnał wejściowy
B0515 B0203 Obwód prędkościomierza - usterka
B0516 B0204 Obwód prędkościomierza - sygnał poza zakresem/wydajność
B0517 B0205 Obwód prędkościomierza - niski sygnał wejściowy
B0518 B0206 Obwód prędkościomierza - wysoki sygnał wejściowy
B0520 B0208 Obwód obrotomierza - usterka
B0521 B0209 Obwód obrotomierza - sygnał poza zakresem/wydajność
B0522 B020A Obwód obrotomierza - niski sygnał wejściowy
B0523 B020B Obwód obrotomierza - wysoki sygnał wejściowy
B0525 B020D Obwód wskaźnika temperatury - usterka
B0526 B020E Obwód wskaźnika temperatury - sygnał poza zakresem/wydajność
B0527 B020F Obwód wskaźnika temperatury - niski sygnał wejściowy
B0528 B0210 Obwód wskaźnika temperatury - wysoki sygnał wejściowy
B0530 B0212 Wskaźnik poziomu paliwa - usterka
B0531 B0213 Wskaźnik poziomu paliwa - sygnał poza zakresem/wydajność
B0532 B0214 Wskaźnik poziomu paliwa - niski sygnał wejściowy
B0533 B0215 Wskaźnik poziomu paliwa - wysoki sygnał wejściowy
B0535 B0217 Obwód turbodoładowania - usterka
B0536 B0218 Obwód turbodoładowania - sygnał poza zakresem/wydajność
B0537 B0219 Obwód turbodoładowania - niski sygnał wejściowy
B0538 B021A Obwód turbodoładowania - wysoki sygnał wejściowy
B0540 B021C Wskaźnik mocowania pasa bezpieczeństwa - usterka
B0541 B021D Wskaźnik mocowania pasa bezpieczeństwa - sygnał poza zakresem/wydajność
B0542 B021E Wskaźnik mocowania pasa bezpieczeństwa - niski sygnał wejściowy
B0543 B021F Wskaźnik mocowania pasa bezpieczeństwa - wysoki sygnał wejściowy
B0545 B0221 Wskaźnik drzwi niezamkniętych #1 - usterka
B0546 B0222 Wskaźnik drzwi niezamkniętych #1 - sygnał poza zakresem/wydajność
B0547 B0223 Wskaźnik drzwi niezamkniętych #1 - niski sygnał wejściowy
B0548 B0224 Wskaźnik drzwi niezamkniętych #1 - wysoki sygnał wejściowy
B0550 B0226 Wskaźnik drzwi niezamkniętych #2 - usterka
B0551 B0227 Wskaźnik drzwi niezamkniętych #2 - sygnał poza zakresem/wydajność
B0552 B0228 Wskaźnik drzwi niezamkniętych #2 - niski sygnał wejściowy
B0553 B0229 Wskaźnik drzwi niezamkniętych #2 - wysoki sygnał wejściowy
B0555 B022B Wskaźnik hamulca - usterka
B0556 B022C Wskaźnik hamulca - sygnał poza zakresem/wydajność
B0557 B022D Wskaźnik hamulca - niski sygnał wejściowy
B0558 B022E Wskaźnik hamulca - wysoki sygnał wejściowy
B0560 B0230 Lampka kontrolna poduszki powietrznej #1 - usterka
B0561 B0231 Lampka kontrolna poduszki powietrznej #1 - sygnał poza zakresem/wydajność
B0562 B0232 Lampka kontrolna poduszki powietrznej #1 - niski sygnał wejściowy
B0563 B0233 Lampka kontrolna poduszki powietrznej #1 - wysoki sygnał wejściowy
B0565 B0235 Obwód zabezpieczenia informacji - usterka
B0566 B0236 Obwód zabezpieczenia informacji - sygnał poza zakresem/wydajność
B0567 B0237 Obwód zabezpieczenia informacji - niski sygnał wejściowy
B0568 B0238 Obwód zabezpieczenia informacji - wysoki sygnał wejściowy
B0600 B0258 Błąd konfiguracji opcji
B0601 B0259 Zerowanie /reset/ KAM
B0602 B025A Układ nadzorujący COP - usterka
B0603 B025B Pamięć EEPROM - błąd zapisu
B0604 B025C Pamięć EEPROM - błąd kalibracji
B0605 B025D Pamięć EEPROM - błąd sumy kontrolnej
B0606 B025E Uszkodzenie pamięci RAM
B0607 B025F Błąd wewnętrzny
B0608 B0260 Błąd inicjalizacji
B0800 B0320 Obwód zasilania urządzenia #1 - usterka
B0801 B0321 Obwód zasilania urządzenia #1 - sygnał poza zakresem/wydajność
B0802 B0322 Obwód zasilania urządzenia #1 - niski sygnał wejściowy
B0803 B0323 Obwód zasilania urządzenia #1 - wysoki sygnał wejściowy
B0805 B0325 Obwód zasilania urządzenia #2 - usterka
B0806 B0326 Obwód zasilania urządzenia #2 - sygnał poza zakresem/wydajność
B0807 B0327 Obwód zasilania urządzenia #2 - niski sygnał wejściowy
B0808 B0328 Obwód zasilania urządzenia #2 - wysoki sygnał wejściowy
B0810 B032A Obwód zasilania urządzenia #3 - usterka
B0811 B032B Obwód zasilania urządzenia #3 - sygnał poza zakresem/wydajność
B0812 B032C Obwód zasilania urządzenia #3 - niski sygnał wejściowy
B0813 B032D Obwód zasilania urządzenia #3 - wysoki sygnał wejściowy
B0815 B032F Obwód masy urządzenia #1 - usterka
B0816 B0330 Obwód masy urządzenia #1 - sygnał poza zakresem/wydajność
B0817 B0331 Obwód masy urządzenia #1 - niski sygnał wejściowy
B0818 B0332 Obwód masy urządzenia #1 - wysoki sygnał wejściowy
B0820 B0334 Obwód masy urządzenia #2 - usterka
B0821 B0335 Obwód masy urządzenia #2 - sygnał poza zakresem/wydajność
B0822 B0336 Obwód masy urządzenia #2 - niski sygnał wejściowy
B0823 B0337 Obwód masy urządzenia #2 - wysoki sygnał wejściowy
B0825 B0339 Obwód masy urządzenia #3 - usterka
B0826 B033A Obwód masy urządzenia #3 - sygnał poza zakresem/wydajność
B0827 B033B Obwód masy urządzenia #3 - niski sygnał wejściowy
B0828 B033C Obwód masy urządzenia #3 - wysoki sygnał wejściowy
B0830 B033E Obwód zapłonu #0 - usterka
B0831 B033F Obwód zapłonu #0 - sygnał poza zakresem/wydajność
B0832 B0340 Obwód zapłonu #0 - niski sygnał wejściowy
B0833 B0341 Obwód zapłonu #0 - wysoki sygnał wejściowy
B0835 B0343 Obwód zapłonu #1 - usterka
B0836 B0344 Obwód zapłonu #1 - sygnał poza zakresem/wydajność
B0837 B0345 Obwód zapłonu #1 - niski sygnał wejściowy
B0838 B0346 Obwód zapłonu #1 - wysoki sygnał wejściowy
B0840 B0348 Obwód zapłonu #3 - usterka
B0841 B0349 Obwód zapłonu #3 - sygnał poza zakresem/wydajność
B0842 B034A Obwód zapłonu #3 - niski sygnał wejściowy
B0843 B034B Obwód zapłonu #3 - wysoki sygnał wyjściowy
B0845 B034D Obwód napięcia odniesienia 5V - usterka
B0846 B034E Obwód napięcia odniesienia 5V - sygnał poza zakresem/wydajność
B0847 B034F Obwód napięcia odniesienia 5V - niski sygnał wejściowy
B0848 B0350 Obwód napięcia odniesienia 5V - wysoki sygnał wejściowy
B0850 B0352 Obwód akumulatora (czystego) - usterka
B0851 B0353 Obwód akumulatora (czystego) - sygnał poza zakresem/wydajność
B0852 B0354 Obwód akumulatora (czystego) - niski sygnał wejściowy
B0853 B0355 Obwód akumulatora (czystego) - wysoki sygnał wejściowy
B0855 B0357 Obwód akumulatora (zanieczyszczonego) - usterka
B0856 B0358 Obwód akumulatora (zanieczyszczonego) - sygnał poza zakresem/wydajność
B0857 B0359 Obwód akumulatora (zanieczyszczonego) - niski sygnał wejściowy
B0858 B035A Obwód akumulatora (zanieczyszczonego) - wysoki sygnał wejściowy
B0859 B035B Napięcie systemu - sygnał zbyt niski
B0860 B035C Napięcie systemu - sygnał zbyt wysoki
C0200 C00C8 Czujnik prędkości koła prawy przedni - usterka
C0201 C00C9 Czujnik prędkości koła prawy przedni - sygnał poza zakresem/wydajność
C0202 C00CA Czujnik prędkości koła prawy przedni - niski sygnał wejściowy
C0203 C00CB Czujnik prędkości koła prawy przedni - wysoki sygnał wejściowy
C0205 C00CD Czujnik prędkości koła lewy przedni - usterka
C0206 C00CE Czujnik prędkości koła lewy przedni - sygnał poza zakresem/wydajność
C0207 C00CF Czujnik prędkości koła lewy przedni - niski sygnał wejściowy
C0208 C00D0 Czujnik prędkości koła lewy przedni - wysoki sygnał wejściowy
C0210 C00D2 Czujnik prędkości koła prawy tylny - usterka
C0211 C00D3 Czujnik prędkości koła prawy tylny - sygnał poza zakresem/wydajność
C0212 C00D4 Czujnik prędkości koła prawy tylny - niski sygnał wejściowy
C0213 C00D5 Czujnik prędkości koła prawy tylny - wysoki sygnał wyjściowy
C0215 C00D7 Czujnik prędkości koła lewy tylny - usterka
C0216 C00D8 Czujnik prędkości koła lewy tylny - sygnał poza zakresem/wydajność
C0217 C00D9 Czujnik prędkości koła lewy tylny - niski sygnał wejściowy
C0218 C00DA Czujnik prędkości koła lewy tylny - wysoki sygnał wejściowy
C0220 C00DC Czujnik prędkości tylnych kół - usterka
C0221 C00DD Czujnik prędkości tylnych kół - sygnał poza zakresem/wydajność
C0222 C00DE Czujnik prędkości tylnych kół - niski sygnał wejściowy
C0223 C00DF Czujnik prędkości tylnych kół - wysoki sygnał wejściowy
C0225 C00E1 Czujnik prędkości kół - błąd częstotliwości
C0226 C00E2 Elektromagnes/miernik #1 ABS prawy przedni - usterka
C0227 C00E3 Elektromagnes/miernik #1 ABS prawy przedni - sygnał poza zakresem/wydajność
C0228 C00E4 Elektromagnes/miernik #1 ABS prawy przedni - niski sygnał wejściowy
C0229 C00E5 Elektromagnes/miernik #1 ABS prawy przedni - wysoki sygnał wejściowy
C0231 C00E7 Elektromagnes/miernik #2 ABS prawy przedni - usterka
C0232 C00E8 Elektromagnes/miernik #2 ABS prawy przedni - sygnał poza zakresem/wydajność
C0233 C00E9 Elektromagnes/miernik #2 ABS prawy przedni - niski sygnał wejściowy
C0234 C00EA Elektromagnes/miernik #2 ABS prawy przedni - wysoki sygnał wejściowy
C0236 C00EC Elektromagnes/miernik #1 ABS lewy przedni - usterka
C0237 C00ED Elektromagnes/miernik #1 ABS lewy przedni - sygnał poza zakresem/wydajność
C0238 C00EE Elektromagnes/miernik #1 ABS lewy przedni - niski sygnał wejściowy
C0239 C00EF Elektromagnes/miernik #1 ABS lewy przedni - wysoki sygnał wejściowy
C0241 C00F1 Elektromagnes/miernik #2 ABS lewy przedni - usterka
C0242 C00F2 Elektromagnes/miernik #2 ABS lewy przedni - sygnał poza zakresem/wydajność
C0243 C00F3 Elektromagnes/miernik #2 ABS lewy przedni - niski sygnał wejściowy
C0244 C00F4 Elektromagnes/miernik #2 ABS lewy przedni - wysoki sygnał wejściowy
C0246 C00F6 Elektromagnes/miernik #1 ABS prawy tylny - usterka
C0247 C00F7 Elektromagnes/miernik #1 ABS prawy tylny - sygnał poza zakresem/wydajność
C0248 C00F8 Elektromagnes/miernik #1 ABS prawy tylny - niski sygnał wejściowy
C0249 C00F9 Elektromagnes/miernik #1 ABS prawy tylny - wysoki sygnał wejściowy
C0251 C00FB Elektromagnes/miernik #2 ABS prawy tylny - usterka
C0252 C00FC Elektromagnes/miernik #2 ABS prawy tylny - sygnał poza zakresem/wydajność
C0253 C00FD Elektromagnes/miernik #2 ABS prawy tylny - niski sygnał wejściowy
C0254 C00FE Elektromagnes/miernik #2 ABS prawy tylny - wysoki sygnał wejściowy
C0256 C0100 Elektromagnes/miernik #1 ABS lewy tylny - usterka
C0257 C0101 Elektromagnes/miernik #1 ABS lewy tylny - sygnał poza zakresem/wydajność
C0258 C0102 Elektromagnes/miernik #1 ABS lewy tylny - niski sygnał wejściowy
C0259 C0103 Elektromagnes/miernik #1 ABS lewy tylny - wysoki sygnał wejściowy
C0261 C0105 Elektromagnes/miernik #2 ABS lewy tylny - usterka
C0262 C0106 Elektromagnes/miernik #2 ABS lewy tylny - sygnał poza zakresem/wydajność
C0263 C0107 Elektromagnes/miernik #2 ABS lewy tylny - niski sygnał wejściowy
C0264 C0108 Elektromagnes/miernik #2 ABS lewy tylny - wysoki sygnał wejściowy
C0266 C010A Obwód silnika pompy - usterka
C0267 C010B Obwód silnika pompy - sygnał poza zakresem/wydajność
C0268 C010C Obwód silnika pompy - niski sygnał wejściowy
C0269 C010D Obwód silnika pompy - wysoki sygnał wejściowy
C0271 C010F Obwód przekaźnika silnika pompy - usterka
C0272 C0110 Obwód przekaźnika silnika pompy - sygnał poza zakresem/wydajność
C0273 C0111 Obwód przekaźnika silnika pompy - niski sygnał wejściowy
C0274 C0112 Obwód przekaźnika silnika pompy - wysoki sygnał wejściowy
C0276 C0114 Obwód przekaźnika zaworu - usterka
C0277 C0115 Obwód przekaźnika zaworu - sygnał poza zakresem/wydajność
C0278 C0116 Obwód przekaźnika zaworu - niski sygnał wejściowy
C0279 C0117 Obwód przekaźnika zaworu - wysoki sygnał wejściowy
C0300 C012C Elektromagnes/miernik TCS #1 prawy przedni - usterka
C0301 C012D Elektromagnes/miernik TCS #1 prawy przedni - sygnał poza zakresem/wydajność
C0302 C012E Elektromagnes/miernik TCS #1 prawy przedni - niski sygnał wejściowy
C0303 C012F Elektromagnes/miernik TCS #1 prawy przedni - wysoki sygnał wejściowy
C0305 C0131 Elektromagnes/miernik TCS #2 prawy przedni - usterka
C0306 C0132 Elektromagnes/miernik TCS #2 prawy przedni - sygnał poza zakresem/wydajność
C0307 C0133 Elektromagnes/miernik TCS #2 prawy przedni - niski sygnał wejściowy
C0308 C0134 Elektromagnes/miernik TCS #2 prawy przedni - wysoki sygnał wejściowy
C0310 C0136 Elektromagnes/miernik TCS #1 lewy przedni - usterka
C0311 C0137 Elektromagnes/miernik TCS #1 lewy przedni - sygnał poza zakresem/wydajność
C0312 C0138 Elektromagnes/miernik TCS #1 lewy przedni - niski sygnał wejściowy
C0313 C0139 Elektromagnes/miernik TCS #1 lewy przedni - wysoki sygnał wejściowy
C0315 C013B Elektromagnes/miernik TCS #2 lewy przedni - usterka
C0316 C013C Elektromagnes/miernik TCS #2 lewy przedni - sygnał poza zakresem/wydajność
C0317 C013D Elektromagnes/miernik TCS #2 lewy przedni - niski sygnał wejściowy
C0318 C013E Elektromagnes/miernik TCS #2 lewy przedni - wysoki sygnał wejściowy
C0320 C0140 Elektromagnes/miernik TCS #1 prawy tylny - usterka
C0321 C0141 Elektromagnes/miernik TCS #1 prawy tylny - sygnał poza zakresem/wydajność
C0322 C0142 Elektromagnes/miernik TCS #1 prawy tylny - niski sygnał wejściowy
C0323 C0143 Elektromagnes/miernik TCS #1 prawy tylny - wysoki sygnał wejściowy
C0325 C0145 Elektromagnes/miernik TCS #2 prawy tylny - usterka
C0326 C0146 Elektromagnes/miernik TCS #2 prawy tylny - sygnał poza zakresem/wydajność
C0327 C0147 Elektromagnes/miernik TCS #2 prawy tylny - niski sygnał wejściowy
C0328 C0148 Elektromagnes/miernik TCS #2 prawy tylny - wysoki sygnał wejściowy
C0330 C014A Elektromagnes/miernik TCS #1 lewy tylny - usterka
C0331 C014B Elektromagnes/miernik TCS #1 lewy tylny - sygnał poza zakresem/wydajność
C0332 C014C Elektromagnes/miernik TCS #1 lewy tylny - niski sygnał wejściowy
C0333 C014D Elektromagnes/miernik TCS #1 lewy tylny - wysoki sygnał wejściowy
C0335 C014F Elektromagnes/miernik TCS #2 lewy tylny - usterka
C0336 C0150 Elektromagnes/miernik TCS #2 lewy tylny - sygnał poza zakresem/wydajność
C0337 C0151 Elektromagnes/miernik TCS #2 lewy tylny - niski sygnał wejściowy
C0338 C0152 Elektromagnes/miernik TCS #2 lewy tylny - wysoki sygnał wejściowy
C0340 C0154 Przełącznik hamulca ABS/TCS - usterka
C0341 C0155 Przełącznik hamulca ABS/TCS - sygnał poza zakresem/wydajność
C0342 C0156 Przełącznik hamulca ABS/TCS - niski sygnał wejściowy
C0343 C0157 Przełącznik hamulca ABS/TCS - wysoki sygnał wejściowy
C0345 C0159 Obwód niskiego poziomu płynu hamulcowego - usterka
C0346 C015A Obwód niskiego poziomu płynu hamulcowego - sygnał poza zakresem/wydajność
C0347 C015B Obwód niskiego poziomu płynu hamulcowego - niski sygnał wejściowy
C0348 C015C Obwód niskiego poziomu płynu hamulcowego - wysoki sygnał wejściowy
C0350 C015E Elektromagnes/miernik #1 tylny - usterka
C0351 C015F Elektromagnes/miernik #1 tylny - sygnał poza zakresem/wydajność
C0352 C0160 Elektromagnes/miernik #1 tylny - niski sygnał wejściowy
C0353 C0161 Elektromagnes/miernik #1 tylny - wysoki sygnał wejściowy
C0355 C0163 Obwód miernika przymykania przepustnicy - usterka
C0356 C0164 Obwód miernika przymykania przepustnicy - sygnał poza zakresem/wydajność
C0357 C0165 Obwód miernika przymykania przepustnicy - niski sygnał wejściowy
C0358 C0166 Obwód miernika przymykania przepustnicy - wysoki sygnał wejściowy
C0360 C0168 Obwód ciśnienia w systemie - usterka
C0361 C0169 Obwód ciśnienia w systemie - sygnał poza zakresem/wydajność
C0362 C016A Obwód ciśnienia w systemie - niski sygnał wejściowy
C0363 C016B Obwód ciśnienia w systemie - wysoki sygnał wejściowy
C0365 C016D Przyspieszeniomierz boczny/poprzeczny/ - usterka
C0366 C016E Przyspieszeniomierz boczny/poprzeczny/ - sygnał poza zakresem/wydajność
C0367 C016F Przyspieszeniomierz boczny/poprzeczny/ - niski sygnał wejściowy
C0368 C0170 Przyspieszeniomierz boczny/poprzeczny/ - wysoki sygnał wejściowy
C0370 C0172 Obwód odchylenia kierunkowego - usterka
C0371 C0173 Obwód odchylenia kierunkowego - sygnał poza zakresem/wydajność
C0372 C0174 Obwód odchylenia kierunkowego - niski sygnał wejściowy
C0373 C0175 Obwód odchylenia kierunkowego - wysoki sygnał wejściowy
C0500 C01F4 Układ wspomagania kierownicy, elektromagnes - usterka
C0501 C01F5 Układ wspomagania kierownicy, elektromagnes - sygnał poza zakresem/wydajność
C0502 C01F6 Układ wspomagania kierownicy, elektromagnes - niski sygnał wejściowy
C0503 C01F7 Układ wspomagania kierownicy, elektromagnes - wysoki sygnał wejściowy
C0505 C01F9 Układ wspomagania, czujnik położenia kierownicy - usterka
C0506 C01FA Układ wspomagania, czujnik położenia kierownicy - sygnał poza zakresem/wydajność
C0507 C01FB Układ wspomagania, czujnik położenia kierownicy - niski sygnał wejściowy
C0508 C01FC Układ wspomagania, czujnik położenia kierownicy - wysoki sygnał wejściowy
C0510 C01FE Czujnik zmiany wielkości położenia kierownicy - usterka
C0511 C01FF Czujnik zmiany wielkości położenia kierownicy - sygnał poza zakresem/wydajność
C0512 C0200 Czujnik zmiany wielkości położenia kierownicy - niski sygnał wejściowy
C0513 C0201 Czujnik zmiany wielkości położenia kierownicy - wysoki sygnał wejściowy
C0700 C02BC Elektromagnes lewy przedni - usterka
C0701 C02BD Elektromagnes lewy przedni - sygnał poza zakresem/wydajność
C0702 C02BE Elektromagnes lewy przedni - niski sygnał wejściowy
C0703 C02BF Elektromagnes lewy przedni - wysoki sygnał wejściowy
C0705 C02C1 Elektromagnes prawy przedni - usterka
C0706 C02C2 Elektromagnes prawy przedni - sygnał poza zakresem/wydajność
C0707 C02C3 Elektromagnes prawy przedni - niski sygnał wejściowy
C0708 C02C4 Elektromagnes prawy przedni - wysoki sygnał wejściowy
C0710 C02C6 Elektromagnes lewy tylny - usterka
C0711 C02C7 Elektromagnes lewy tylny - sygnał poza zakresem/wydajność
C0712 C02C8 Elektromagnes lewy tylny - niski sygnał wejściowy
C0713 C02C9 Elektromagnes lewy tylny - wysoki sygnał wejściowy
C0715 C02CB Elektromagnes prawy tylny - usterka
C0716 C02CC Elektromagnes prawy tylny - sygnał poza zakresem/wydajność
C0717 C02CD Elektromagnes prawy tylny - niski sygnał wejściowy
C0718 C02CE Elektromagnes prawy tylny - wysoki sygnał wejściowy
C0720 C02D0 Przyspieszeniomierz lewy przedni - usterka
C0721 C02D1 Przyspieszeniomierz lewy przedni - sygnał poza zakresem/wydajność
C0722 C02D2 Przyspieszeniomierz lewy przedni - niski sygnał wejściowy
C0723 C02D3 Przyspieszeniomierz lewy przedni - wysoki sygnał wejściowy
C0725 C02D5 Przyspieszeniomierz prawy przedni - usterka
C0726 C02D6 Przyspieszeniomierz prawy przedni - sygnał poza zakresem/wydajność
C0727 C02D7 Przyspieszeniomierz prawy przedni - niski sygnał wejściowy
C0728 C02D8 Przyspieszeniomierz prawy przedni - wysoki sygnał wejściowy
C0730 C02DA Przyspieszeniomierz lewy tylny - usterka
C0731 C02DB Przyspieszeniomierz lewy tylny - sygnał poza zakresem/wydajność
C0732 C02DC Przyspieszeniomierz lewy tylny - niski sygnał wejściowy
C0733 C02DD Przyspieszeniomierz lewy tylny - wysoki sygnał wejściowy
C0735 C02DF Przyspieszeniomierz prawy tylny - usterka
C0736 C02E0 Przyspieszeniomierz prawy tylny - sygnał poza zakresem/wydajność
C0737 C02E1 Przyspieszeniomierz prawy tylny - niski sygnał wejściowy
C0738 C02E2 Przyspieszeniomierz prawy tylny - wysoki sygnał wejściowy
C0740 C02E4 Czujnik położenia lewy przedni - usterka
C0741 C02E5 Czujnik położenia lewy przedni - sygnał poza zakresem/wydajność
C0742 C02E6 Czujnik położenia lewy przedni - niski sygnał wejściowy
C0743 C02E7 Czujnik położenia lewy przedni - wysoki sygnał wejściowy
C0745 C02E9 Czujnik położenia prawy przedni - usterka
C0746 C02EA Czujnik położenia prawy przedni - sygnał poza zakresem/wydajność
C0747 C02EB Czujnik położenia prawy przedni - niski sygnał wejściowy
C0748 C02EC Czujnik położenia prawy przedni - wysoki sygnał wejściowy
C0750 C02EE Czujnik położenia lewy tylny - usterka
C0751 C02EF Czujnik położenia lewy tylny - sygnał poza zakresem/wydajność
C0752 C02F0 Czujnik położenia lewy tylny - niski sygnał wejściowy
C0753 C02F1 Czujnik położenia lewy tylny - wysoki sygnał wejściowy
C0755 C02F3 Czujnik położenia prawy tylny - usterka
C0756 C02F4 Czujnik położenia prawy tylny - sygnał poza zakresem/wydajność
C0757 C02F5 Czujnik położenia prawy tylny - niski sygnał wejściowy
C0758 C02F6 Czujnik położenia prawy tylny - wysoki sygnał wejściowy
PostNapisane: 2 paź 2012, o 21:47
P0100 P0064 Czujnik masowego lub objętościowego przepływu powietrza - usterka
P0101 P0065 Czujnik masowego lub objętościowego przepływu powietrza - sygnał poza zakresem/wydajność
P0102 P0066 Czujnik masowego lub objętościowego przepływu powietrza - niski sygnał wejściowy
P0103 P0067 Czujnik masowego lub objętościowego przepływu powietrza - wysoki sygnał wejściowy
P0104 P0068 Czujnik masowego lub objętościowego przepływu powietrza - przerwa
P0105 P0069 Czujnik ciśnienia absol.kolektora/ciśnienia atmosferycznego - usterka
P0106 P006A Czujnik ciśnienia absol.kolektora/ciśnienia atmosferycznego - sygnał poza zakresem/wydajność
P0107 P006B Czujnik ciśnienia absol.kolektora/ciśnienia atmosferycznego - niski sygnał wejściowy
P0108 P006C Czujnik ciśnienia absol.kolektora/ciśnienia atmosferycznego - wysoki sygnał wejściowy
P0109 P006D Czujnik ciśnienia absol.kolektora/ciśnienia atmosferycznego - przerwa
P0110 P006E Czujnik temp. powietrza wlotowego - usterka
P0111 P006F Czujnik temp. powietrza wlotowego - sygnał poza zakresem/wydajność
P0112 P0070 Czujnik temp. powietrza wlotowego - niski sygnał wejściowy
P0113 P0071 Czujnik temp. powietrza wlotowego - wysoki sygnał wejściowy
P0114 P0072 Czujnik temp. powietrza wlotowego - przerwa
P0115 P0073 Czujnik temp. czynnika chłodzącego silnik - usterka
P0116 P0074 Czujnik temp. czynnika chłodzącego silnik - sygnał poza zakresem/wydajność
P0117 P0075 Czujnik temp. czynnika chłodzącego silnik - niski sygnał wejściowy
P0118 P0076 Czujnik temp. czynnika chłodzącego silnik - wysoki sygnał wejściowy
P0119 P0077 Czujnik temp. czynnika chłodzącego silnik - przerwa
P0120 P0078 Przepustnica /czujnik położenia pedału /przełącznik A - usterka
P0121 P0079 Przepustnica /czujnik położenia pedału /przełącznik A - sygnał poza zakresem/wydajność
P0122 P007A Przepustnica /czujnik położenia pedału /przełącznik A - niski sygnał wejściowy
P0123 P007B Przepustnica /czujnik położenia pedału /przełącznik A - wysoki sygnał wejściowy
P0124 P007C Przepustnica /czujnik położenia pedału /przełącznik A - przerwa
P0125 P007D Niewystarczająca temp. czynnika chłodzącego dla zamkniętej pętli regulacji paliwa
P0126 P007E Niewystarczająca temp. czynnika chłodzącego dla stabilnej pracy
P0130 P0082 Czujnik O2 (Bank 1 Czujnik 1) - usterka
P0131 P0083 Czujnik O2 (Bank 1 Czujnik 1) - niskie napięcie
P0132 P0084 Czujnik O2 (Bank 1 Czujnik 1) - wysokie napięcie
P0133 P0085 Czujnik O2 (Bank 1 Czujnik 1) - powolna reakcja /odpowiedź/
P0134 P0086 Czujnik O2 (Bank 1 Czujnik 1) - brak aktywności
P0135 P0087 Podgrzewacz czujnika O2 (Bank 1 Czujnik 1) - usterka
P0136 P0088 Czujnik O2 (Bank 1 Czujnik 2) - usterka
P0137 P0089 Czujnik O2 (Bank 1 Czujnik 2) - niskie napięcie
P0138 P008A Czujnik O2 (Bank 1 Czujnik 2) - wysokie napięcie
P0139 P008B Czujnik O2 (Bank 1 Czujnik 2) - powolna reakcja
P0140 P008C Czujnik O2 (Bank 1 Czujnik 2) - brak aktywności
P0141 P008D Podgrzewacz czujnika O2 (Bank 1 Czujnik 2) - usterka
P0142 P008E Czujnik O2 (Bank 1 Czujnik 3) - usterka
P0143 P008F Czujnik O2 (Bank 1 Czujnik 3) - niskie napięcie
P0144 P0090 Czujnik O2 (Bank 1 Czujnik 3) - wysokie napięcie
P0145 P0091 Czujnik O2 (Bank 1 Czujnik 3) - powolna reakcja
P0146 P0092 Czujnik O2 (Bank 1 Czujnik 3) - brak aktywności
P0147 P0093 Podgrzewacz czujnika O2 (Bank 1 Czujnik 3) - usterka
P0150 P0096 Czujnik O2 (Bank 2 Czujnik 1) - usterka
P0151 P0097 Czujnik O2 (Bank 2 Czujnik 1) - niskie napięcie
P0152 P0098 Czujnik O2 (Bank 2 Czujnik 1) - wysokie napięcie
P0153 P0099 Czujnik O2 (Bank 2 Czujnik 1) - powolna reakcja
P0154 P009A Czujnik O2 (Bank 2 Czujnik 1) - brak aktywności
P0155 P009B Podgrzewacz czujnika O2 (Bank 2 Czujnik 1) - usterka
P0156 P009C Czujnik O2 (Bank 2 Czujnik 2) - usterka
P0157 P009D Czujnik O2 (Bank 2 Czujnik 2) - niskie napięcie
P0158 P009E Czujnik O2 (Bank 2 Czujnik 2) - wysokie napięcie
P0159 P009F Czujnik O2 (Bank 2 Czujnik 2) - powolna reakcja
P0160 P00A0 Czujnik O2 (Bank 2 Czujnik 2) - brak aktywności
P0161 P00A1 Podgrzewacz czujnika O2 (Bank 2 Czujnik 2) - usterka
P0162 P00A2 Czujnik O2 (Bank 2 Czujnik 3) - usterka
P0163 P00A3 Czujnik O2 (Bank 2 Czujnik 3) - niskie napięcie
P0164 P00A4 Czujnik O2 (Bank 2 Czujnik 3) - wysokie napięcie
P0165 P00A5 Czujnik O2 (Bank 2 Czujnik 3) - powolna reakcja
P0166 P00A6 Czujnik O2 (Bank 2 Czujnik 3) - brak aktywności
P0167 P00A7 Podgrzewacz czujnika O2 (Bank 2 Czujnik 3) - usterka
P0170 P00AA Czujnik O2 (Bank 1) - usterka dostrajania paliwa
P0171 P00AB Czujnik O2 (Bank 1) - mieszanka zbyt uboga
P0172 P00AC Czujnik O2 (Bank 1) - mieszanka zbyt bogata
P0173 P00AD Czujnik O2 (Bank 2) - usterka dostrajania paliwa
P0174 P00AE Czujnik O2 (Bank 2) - mieszanka zbyt uboga
P0175 P00AF Czujnik O2 (Bank 2) - mieszanka zbyt bogata
P0176 P00B0 Czujnik składu paliwa - usterka
P0177 P00B1 Czujnik składu paliwa - sygnał poza zakresem/wydajność
P0178 P00B2 Czujnik składu paliwa - niski sygnał wejściowy
P0179 P00B3 Czujnik składu paliwa - wysoki sygnał wejściowy
P0180 P00B4 Czujnik A temp. paliwa - usterka
P0181 P00B5 Czujnik A temp. paliwa - sygnał poza zakresem/wydajność
P0182 P00B6 Czujnik A temp. paliwa - niski sygnał wejściowy
P0183 P00B7 Czujnik A temp. paliwa - wysoki sygnał wejściowy
P0184 P00B8 Czujnik A temp. paliwa - przerwa
P0185 P00B9 Czujnik B temp. paliwa - usterka
P0186 P00BA Czujnik B temp. paliwa - sygnał poza zakresem/wydajność
P0187 P00BB Czujnik B temp. paliwa - niski sygnał wejściowy
P0188 P00BC Czujnik B temp. paliwa - wysoki sygnał wejściowy
P0189 P00BD Czujnik B temp. paliwa - przerwa
P0190 P00BE Czujnik ciśnienia zbiornika zasilania (listwy) paliwa - usterka
P0191 P00BF Czujnik ciśnienia zbiornika zasilania (listwy) paliwa - sygnał poza zakresem/wydajność
P0192 P00C0 Czujnik ciśnienia zbiornika zasilania (listwy) paliwa - niski sygnał wejściowy
P0193 P00C1 Czujnik ciśnienia zbiornika zasilania (listwy) paliwa - wysoki sygnał wejściowy
P0194 P00C2 Czujnik ciśnienia listwy paliwowej - przerwa
P0195 P00C3 Czujnik temp. oleju silnika - usterka
P0196 P00C4 Czujnik temp. oleju silnika - sygnał poza zakresem/wydajność
P0197 P00C5 Czujnik temp. oleju silnika - niski sygnał wejściowy
P0198 P00C6 Czujnik temp. oleju silnika - wysoki sygnał wejściowy
P0199 P00C7 Czujnik temp. oleju silnika - przerwa
P0200 P00C8 Obwód wtryskiwacza - usterka
P0201 P00C9 Obwód wtryskiwacza, cylinder 1 - usterka
P0202 P00CA Obwód wtryskiwacza, cylinder 2 - usterka
P0203 P00CB Obwód wtryskiwacza, cylinder 3 - usterka
P0204 P00CC Obwód wtryskiwacza, cylinder 4 - usterka
P0205 P00CD Obwód wtryskiwacza, cylinder 5 - usterka
P0206 P00CE Obwód wtryskiwacza, cylinder 6 - usterka
P0207 P00CF Obwód wtryskiwacza, cylinder 7 - usterka
P0208 P00D0 Obwód wtryskiwacza, cylinder 8 - usterka
P0209 P00D1 Obwód wtryskiwacza, cylinder 9 - usterka
P0210 P00D2 Obwód wtryskiwacza, cylinder 10 - usterka
P0211 P00D3 Obwód wtryskiwacza, cylinder 11 - usterka
P0212 P00D4 Obwód wtryskiwacza, cylinder 12 - usterka
P0213 P00D5 Zimny rozruch wtryskiwacza 1 - usterka
P0214 P00D6 Zimny rozruch wtryskiwacza 2 - usterka
P0215 P00D7 Elektromagnes/cewka odcięcia silnika - usterka
P0216 P00D8 Układ kontroli czasu wtrysku - usterka
P0217 P00D9 Stan nadmiernej temp. silnika
P0218 P00DA Stan nadmiernej temp. skrzyni biegów
P0219 P00DB Stan nadmiernej prędkości obrotowej silnika
P0220 P00DC Przepustnica /czujnik położenia pedału /przełącznik B - usterka
P0221 P00DD Przepustnica /czujnik położenia pedału /przełącznik B - sygnał poza zakresem/wydajność
P0222 P00DE Przepustnica /czujnik położenia pedału /przełącznik B - niski sygnał wejściowy
P0223 P00DF Przepustnica /czujnik położenia pedału /przełącznik B - wysoki sygnał wejściowy
P0224 P00E0 Przepustnica /czujnik położenia pedalu /przełącznik B - przerwa
P0225 P00E1 Przepustnica /czujnik położenia pedału /przełącznik C - usterka
P0226 P00E2 Przepustnica /czujnik położenia pedału /przełącznik C - sygnał poza zakresem/wydajność
P0227 P00E3 Przepustnica /czujnik położenia pedału /przełącznik C - niski sygnał wejściowy
P0228 P00E4 Przepustnica /czujnik położenia pedału /przełącznik C - wysoki sygnał wejściowy
P0229 P00E5 Przepustnica /czujnik położenia pedału /przełącznik C - przerwa
P0230 P00E6 Pompa paliwowa, obwód pierwotny - usterka
P0231 P00E7 Pompa paliwowa, obwód wtórny - niski sygnał
P0232 P00E8 Pompa paliwowa, obwód wtórny - wysoki sygnał
P0233 P00E9 Pompa paliwowa, obwód wtórny - przerwa
P0234 P00EA Stan przeładowania /nadmiernego ładowania/ silnika
P0235 P00EB Czujnik A wspomagania turbosprężarki - usterka
P0236 P00EC Czujnik A wspomagania turbosprężarki - sygnał poza zakresem/wydajność
P0237 P00ED Czujnik A wspomagania turbosprężarki - niski sygnał wejściowy
P0238 P00EE Czujnik A wspomagania turbosprężarki - wysoki sygnał wejściowy
P0239 P00EF Czujnik B wspomagania turbosprężarki - usterka
P0240 P00F0 Czujnik B wspomagania turbosprężarki - sygnał poza zakresem/wydajność
P0241 P00F1 Czujnik B wspomagania turbosprężarki - niski sygnał wejściowy
P0242 P00F2 Czujnik B wspomagania turbosprężarki - wysoki sygnał wejściowy
P0243 P00F3 Elektromagnes A przepustnicy spalin turbosprężarki - usterka
P0244 P00F4 Elektromagnes A przepustnicy spalin turbosprężarki - sygnał poza zakresem/wydajność
P0245 P00F5 Elektromagnes A przepustnicy spalin turbosprężarki - niski sygnał
P0246 P00F6 Elektromagnes A przepustnicy spalin turbosprężarki - wysoki sygnał
P0247 P00F7 Elektromagnes B przepustnicy spalin turbosprężarki - usterka
P0248 P00F8 Elektromagnes B przepustnicy spalin turbosprężarki - sygnał poza zakresem/wydajność
P0249 P00F9 Elektromagnes B przepustnicy spalin turbosprężarki - niski sygnał
P0250 P00FA Elektromagnes B przepustnicy spalin turbosprężarki - wysoki sygnał
P0251 P00FB Wirnik/krzywka pompy wtryskowej A - usterka
P0252 P00FC Wirnik/krzywka pompy wtryskowej A - sygnał poza zakresem/wydajność
P0253 P00FD Wirnik/krzywka pompy wtryskowej A - niski sygnał
P0254 P00FE Wirnik/krzywka pompy wtryskowej A - wysoki sygnał
P0255 P00FF Wirnik/krzywka pompy wtryskowej A - przerwa
P0256 P0100 Wirnik/krzywka pompy wtryskowej B - usterka
P0257 P0101 Wirnik/krzywka pompy wtryskowej B - sygnał poza zakresem/wydajność
P0258 P0102 Wirnik/krzywka pompy wtryskowej B - niski sygnał
P0259 P0103 Wirnik/krzywka pompy wtryskowej B - wysoki sygnał
P0260 P0104 Wirnik/krzywka pompy wtryskowej B - przerwa
P0261 P0105 Wtryskiwacz cylindra 1 - niski sygnał
P0262 P0106 Wtryskiwacz cylindra 1 - wysoki sygnał
P0263 P0107 Cylinder 1 - błąd udziału /zrównoważenia
P0264 P0108 Wtryskiwacz cylindra 2 - niski sygnał
P0265 P0109 Wtryskiwacz cylindra 2 - wysoki sygnał
P0266 P010A Cylinder 2 - błąd udziału /zrównoważenia
P0267 P010B Wtryskiwacz cylindra 3 - niski sygnał
P0268 P010C Wtryskiwacz cylindra 3 - wysoki sygnał
P0269 P010D Cylinder 3 - błąd udziału /zrównoważenia
P0270 P010E Wtryskiwacz cylindra 4 - niski sygnał
P0271 P010F Wtryskiwacz cylindra 4 - wysoki sygnał
P0272 P0110 Cylinder 4 - błąd udziału /zrównoważenia
P0273 P0111 Wtryskiwacz cylindra 5 - niski sygnał
P0274 P0112 Wtryskiwacz cylindra 5 - wysoki sygnał
P0275 P0113 Cylinder 5 - błąd udziału /zrównoważenia
P0276 P0114 Wtryskiwacz cylindra 6 - niski sygnał
P0277 P0115 Wtryskiwacz cylindra 6 - wysoki sygnał
P0278 P0116 Cylinder 6 - błąd udziału /zrównoważenia
P0279 P0117 Wtryskiwacz cylindra 7 - niski sygnał
P0280 P0118 Wtryskiwacz cylindra 7 - wysoki sygnał
P0281 P0119 Cylinder 7 - błąd udziału /zrównoważenia
P0282 P011A Wtryskiwacz cylindra 8 - niski sygnał
P0283 P011B Wtryskiwacz cylindra 8 - wysoki sygnał
P0284 P011C Cylinder 8 - błąd udziału /zrównoważenia
P0285 P011D Wtryskiwacz cylindra 9 - niski sygnał
P0286 P011E Wtryskiwacz cylindra 9 - wysoki sygnał
P0287 P011F Cylinder 9 - błąd udziału /zrównoważenia
P0288 P0120 Wtryskiwacz cylindra 10 - niski sygnał
P0289 P0121 Wtryskiwacz cylindra 10 - wysoki sygnał
P0290 P0122 Cylinder 10 - błąd udziału /zrównoważenia
P0291 P0123 Wtryskiwacz cylindra 11 - niski sygnał
P0292 P0124 Wtryskiwacz cylindra 11 - wysoki sygnał
P0293 P0125 Cylinder 11 - błąd udziału /zrównoważenia
P0294 P0126 Wtryskiwacz cylindra 12 - niski sygnał
P0295 P0127 Wtryskiwacz cylindra 12 - wysoki sygnał
P0296 P0128 Cylinder 12 - błąd udziału /zrównoważenia
P0300 P012C Wykryte przypadkowe/wielokrotne wypadanie zapłonów w cylindrach
P0301 P012D Cylinder 1 - wykryte wypadanie zapłonów
P0302 P012E Cylinder 2 - wykryte wypadanie zapłonów
P0303 P012F Cylinder 3 - wykryte wypadanie zapłonów
P0304 P0130 Cylinder 4 - wykryte wypadanie zapłonów
P0305 P0131 Cylinder 5 - wykryte wypadanie zapłonów
P0306 P0132 Cylinder 6 - wykryte wypadanie zapłonów
P0307 P0133 Cylinder 7 - wykryte wypadanie zapłonów
P0308 P0134 Cylinder 8 - wykryte wypadanie zapłonów
P0309 P0135 Cylinder 9 - wykryte wypadanie zapłonów
P0310 P0136 Cylinder 10 - wykryte wypadanie zapłonów
P0311 P0137 Cylinder 11 - wykryte wypadanie zapłonów
P0312 P0138 Cylinder 12 - wykryte wypadanie zapłonów
P0320 P0140 Obwód wejścia prędkości silnika dla rozdzielacza /zapłonu - usterka
P0321 P0141 Obwód wejścia prędkości silnika dla rozdzielacza /zapłonu - sygnał poza zakresem/wydajność
P0322 P0142 Obwód wejścia prędkości silnika dla rozdzielacza /zapłonu - brak sygnału
P0323 P0143 Obwód wejścia prędkości silnika dla rozdzielacza /zaplonu - przerwa
P0325 P0145 Czujnik spalania stukowego 1 (Bank 1 lub poj.czujnik) - usterka
P0326 P0146 Czujnik spalania stukowego 1 (Bank 1 lub poj.czujnik) - sygnał poza zakresem/wydajność
P0327 P0147 Czujnik spalania stukowego 1 (Bank 1 lub poj.czujnik) - niski sygnał wejściowy
P0328 P0148 Czujnik spalania stukowego 1 (Bank 1 lub poj.czujnik) - wysoki sygnał wejściowy
P0329 P0149 Czujnik spalania stukowego 1 (Bank 1 lub poj.czujnik) - przerwa
P0330 P014A Czujnik spalania stukowego 2 (Bank 2) - usterka
P0331 P014B Czujnik spalania stukowego 2 (Bank 2) - sygnał poza zakresem/wydajność
P0332 P014C Czujnik spalania stukowego 2 (Bank 2) - niski sygnał wejściowy
P0333 P014D Czujnik spalania stukowego 2 (Bank 2) - wysoki sygnał wejściowy
P0334 P014E Czujnik spalania stukowego 2 (Bank 2) - przerwa
P0335 P014F Czujnik A położenia wału korbowego - usterka
P0336 P0150 Czujnik A położenia wału korbowego - sygnał poza pawidłowym zakresem
P0337 P0151 Czujnik A położenia wału korbowego - niski sygnał wejściowy
P0338 P0152 Czujnik A położenia wału korbowego - wysoki sygnał wejściowy
P0339 P0153 Czujnik A położenia wału korbowego - przerwa
P0340 P0154 Czujnik polożenia wału rozrządu - usterka
P0341 P0155 Czujnik położenia wału rozrządu - sygnał poza zakresem/wydajność
P0342 P0156 Czujnik położenia wału rozrządu - niski sygnał wejściowy
P0343 P0157 Czujnik położenia wału rozrządu - wysoki sygnał wejściowy
P0344 P0158 Czujnik położenia wału rozrządu - przerwa
P0350 P015E Obwód pierwotny/wtórny cewki zapłonowej - usterka
P0351 P015F Obwód pierwotny/wtórny cewki zapłonowej A - usterka
P0352 P0160 Obwód pierwotny/wtórny cewki zapłonowej B - usterka
P0353 P0161 Obwód pierwotny/wtórny cewki zapłonowej C - usterka
P0354 P0162 Obwód pierwotny/wtórny cewki zapłonowej D - usterka
P0355 P0163 Obwód pierwotny/wtórny cewki zapłonowej E - usterka
P0356 P0164 Obwód pierwotny/wtórny cewki zapłonowej F - usterka
P0357 P0165 Obwód pierwotny/wtórny cewki zapłonowej G - usterka
P0358 P0166 Obwód pierwotny/wtórny cewki zapłonowej H - usterka
P0359 P0167 Obwód pierwotny/wtórny cewki zapłonowej I - usterka
P0360 P0168 Obwód pierwotny/wtórny cewki zapłonowej J - usterka
P0361 P0169 Obwód pierwotny/wtórny cewki zapłonowej K - usterka
P0362 P016A Obwód pierwotny/wtórny cewki zapłonowej L - usterka
P0370 P0172 Czasowy sygnał referencyjny A o wysokiej rozdzielczości - usterka
P0371 P0173 Czasowy sygnał referencyjny A o wysokiej rozdzielczości - za dużo impulsów
P0372 P0174 Czasowy sygnał referencyjny A o wysokiej rozdzielczości - za mało impulsów
P0373 P0175 Czasowy sygnał referencyjny A o wysokiej rozdzielczości - impulsy błędne /przerwa
P0374 P0176 Czasowy sygnał referencyjny A o wysokiej rozdzielczości - brak impulsów
P0375 P0177 Czasowy sygnał referencyjny B o wysokiej rozdzielczości - usterka
P0376 P0178 Czasowy sygnał referencyjny B o wysokiej rozdzielczości - za dużo impulsów
P0377 P0179 Czasowy sygnał referencyjny B o wysokiej rozdzielczości - za mało impulsów
P0378 P017A Czasowy sygnał referencyjny B o wysokiej rozdzielczości - impulsy błędne /przerwa
P0379 P017B Czasowy sygnał referencyjny B o wysokiej rozdzielczości - brak impulsów
P0380 P017C Obwód grzałki /świecy żarowej - usterka
P0381 P017D Obwód wskaźnika grzałki /świecy żarowej - usterka
P0382 P017E Obwód grzałki /świecy żarowej B - usterka
P0385 P0181 Czujnik B położenia wału korbowego - usterka
P0386 P0182 Czujnik B położenia wału korbowego - sygnał poza zakresem/wydajność
P0387 P0183 Czujnik B położenia wału korbowego - niski sygnał wejściowy
P0388 P0184 Czujnik B położenia wału korbowego - wysoki sygnał wejściowy
P0389 P0185 Czujnik B położenia wału korbowego - przerwa
P0400 P0190 Układ recyrkulacji spalin - błedny przepływ
P0401 P0191 Układ recyrkulacji spalin - wykryty niewystarczający przepływ
P0402 P0192 Układ recyrkulacji spalin - wykryty nadmierny przepływ
P0403 P0193 Układ recyrkulacji spalin - usterka
P0404 P0194 Układ recyrkulacji spalin - sygnał poza zakresem/wydajność
P0405 P0195 Czujnik A recyrkulacji spalin - niski sygnał wejściowy
P0406 P0196 Czujnik A recyrkulacji spalin - wysoki sygnał wejściowy
P0407 P0197 Czujnik B recyrkulacji spalin - niski sygnał wejściowy
P0408 P0198 Czujnik B recyrkulacji spalin - wysoki sygnał wejściowy
P0410 P019A System wtrysku powietrza wtórnego - usterka
P0411 P019B System wtrysku powietrza wtórnego - wykryty nieprawidłowy przepływ
P0412 P019C System wtrysku powietrza wtórnego, zawór przełączający A - usterka
P0413 P019D System wtrysku powietrza wtórnego, zawór przełączający A - przerwa
P0414 P019E System wtrysku powietrza wtórnego, zawór przełączający A - zwarcie
P0415 P019F System wtrysku powietrza wtórnego, zawór przełączający B - usterka
P0416 P01A0 System wtrysku powietrza wtórnego, zawór przełączający B - przerwa
P0417 P01A1 System wtrysku powietrza wtórnego, zawór przełączający B - zwarcie
P0418 P01A2 System wtrysku powietrza wtórnego, przekaźnik A - usterka
P0419 P01A3 System wtrysku powietrza wtórnego, przekaźnik B - usterka
P0420 P01A4 System katalizatora (Bank 1) - wydajność poniżej progu
P0421 P01A5 Nagrzany katalizator (Bank 1) - wydajność poniżej progu
P0422 P01A6 Główny katalizator (Bank 1) - wydajność poniżej progu
P0423 P01A7 Grzany katalizator (Bank 1) - wydajność poniżej progu
P0424 P01A8 Grzany katalizator (Bank 1) - temperatura poniżej progu
P0430 P01AE System katalizatora (Bank 2) - wydajność poniżej progu
P0431 P01AF Nagrzany katalizator (Bank 2) - wydajność poniżej progu
P0432 P01B0 Główny katalizator (Bank 2) - wydajność poniżej progu
P0433 P01B1 Grzany katalizator (Bank 2) - wydajność poniżej progu
P0434 P01B2 Grzany katalizator (Bank 2) - temperatura poniżej progu
P0440 P01B8 Układ odprowadzania par paliwa - usterka
P0441 P01B9 Układ odprowadzania par paliwa - błędny przepływ oczyszczania
P0442 P01BA Układ odprowadzania par paliwa - wykryta nieszczelność (mała)
P0443 P01BB Układ odprowadzania par paliwa, obwód ster.zaworu oczyszcz. - usterka
P0444 P01BC Układ odprowadzania par paliwa, obwód ster.zaworu oczyszcz. - przerwa
P0445 P01BD Układ odprowadzania par paliwa, obwód ster.zaworu oczyszcz. - zwarcie
P0446 P01BE Układ odprowadzania par paliwa, obwód ster.went. - usterka
P0447 P01BF Układ odprowadzania par paliwa, obwód ster.went. - przerwa
P0448 P01C0 Układ odprowadzania par paliwa, obwód ster.went. - zwarcie
P0449 P01C1 Układ odprowadzania par paliwa - usterka serwomotoru/uzwojenia zaworu odpowietrznika
P0450 P01C2 Układ odprowadzania par paliwa, czujnik ciśnienia - usterka
P0451 P01C3 Układ odprowadzania par paliwa, czujnik ciśnienia - sygnał poza zakresem/wydajność
P0452 P01C4 Układ odprowadzania par paliwa, czujnik ciśnienia - niski sygnał wejściowy
P0453 P01C5 Układ odprowadzania par paliwa, czujnik ciśnienia - wysoki sygnał wejściowy
P0454 P01C6 Układ odprowadzania par paliwa, czujnik ciśnienia - przerwa
P0455 P01C7 Układ odprowadzania par paliwa - wykryta nieszczelność (duża)
P0456 P01C8 Układ odprowadzania par paliwa - wykryta nieszczelność (b.mała)
P0460 P01CC Czujnik poziomu paliwa - usterka
P0461 P01CD Czujnik poziomu paliwa - sygnał poza zakresem/wydajność
P0462 P01CE Czujnik poziomu paliwa - niski sygnał wejściowy
P0463 P01CF Czujnik poziomu paliwa - wysoki sygnał wejściowy
P0464 P01D0 Czujnik poziomu paliwa - przerwa
P0465 P01D1 Czujnik przepływu oczyszcz. - usterka
P0466 P01D2 Czujnik przepływu oczyszcz. - sygnał poza zakresem/wydajność
P0467 P01D3 Czujnik przepływu oczyszcz. - niski sygnał wejściowy
P0468 P01D4 Czujnik przepływu oczyszcz. - wysoki sygnał wejściowy
P0469 P01D5 Czujnik przepływu oczyszcz. - przerwa
P0470 P01D6 Czujnik ciśnienia wylotowego - usterka
P0471 P01D7 Czujnik ciśnienia wylotowego - sygnał poza zakresem/wydajność
P0472 P01D8 Czujnik ciśnienia wylotowego - niski sygnał wejściowy
P0473 P01D9 Czujnik ciśnienia wylotowego - wysoki sygnał wejściowy
P0474 P01DA Czujnik ciśnienia wylotowego - przerwa
P0475 P01DB Zawór kontrolny ciśnienia wylotowego - usterka
P0476 P01DC Zawór kontrolny ciśnienia wylotowego - sygnał poza zakresem/wydajność
P0477 P01DD Zawór kontrolny ciśnienia wylotowego - niski sygnał wejściowy
P0478 P01DE Zawór kontrolny ciśnienia wylotowego - wysoki sygnał wejściowy
P0479 P01DF Zawór kontrolny ciśnienia wylotowego - przerwa
P0480 P01E0 Obwód kontroli wentylatora chłodzącego 1 - usterka
P0481 P01E1 Obwód kontroli wentylatora chłodzącego 2 - usterka
P0482 P01E2 Obwód kontroli wentylatora chłodzącego 3 - usterka
P0483 P01E3 Obwód wentylatora chłodzącego - kontrola racjonalności
P0484 P01E4 Obwód wentylatora chłodzącego - nadmierny prąd
P0485 P01E5 Obwód zasilania/masy wentylatora chłodzącego - usterka
P0500 P01F4 Czujnik prędkości pojazdu - usterka
P0501 P01F5 Czujnik prędkości pojazdu - sygnał poza zakresem/wydajność
P0502 P01F6 Czujnik prędkości pojazdu - niski sygnał wejściowy
P0503 P01F7 Czujnik prędkości pojazdu - wysoki/błędny/przerywany sygnał
P0505 P01F9 Układ regulacji biegu jałowego - usterka
P0506 P01FA Układ regulacji biegu jałowego - obroty niższe niż oczekiwane
P0507 P01FB Układ regulacji biegu jałowego - obroty wyższe niż oczekiwane
P0510 P01FE Przełącznik położenia zamkniętej przepustnicy - usterka
P0520 P0208 Przełącznik ciśnienia oleju silnika - usterka
P0521 P0209 Przełącznik ciśnienia oleju silnika - sygnał poza zakresem/wydajność
P0522 P020A Przełącznik ciśnienia oleju silnika - niski sygnał wejściowy
P0523 P020B Przełącznik ciśnienia oleju silnika - wysoki sygnał wejściowy
P0530 P0212 Czujnik ciśnienia czynnika chłodzącego A/C - usterka
P0531 P0213 Czujnik ciśnienia czynnika chłodzącego A/C - sygnał poza zakresem/wydajność
P0532 P0214 Czujnik ciśnienia czynnika chłodzącego A/C - niski sygnał wejściowy
P0533 P0215 Czujnik ciśnienia czynnika chłodzącego A/C - wysoki sygnał wejściowy
P0534 P0216 Ubytek ładunku czynnika chłodzącego A/C
P0540 P021C Układ kontroli grzałki powietrza wlotowego - usterka
P0541 P021D Układ kontroli grzałki powietrza wlotowego - niski sygnał
P0542 P021E Układ kontroli grzałki powietrza wlotowego - wysoki sygnał
P0550 P0226 Czujnik ciśnienia układu wspomagania - usterka
P0551 P0227 Czujnik ciśnienia układu wspomagania - sygnał poza zakresem/wydajność
P0552 P0228 Czujnik ciśnienia układu wspomagania - niski sygnał wejściowy
P0553 P0229 Czujnik ciśnienia układu wspomagania - wysoki sygnał wejściowy
P0554 P022A Czujnik ciśnienia układu wspomagania - przerwa
P0560 P0230 Napięcie zasilania systemu - usterka
P0561 P0231 Napięcie zasilania systemu - niestabilny sygnał
P0562 P0232 Napięcie zasilania systemu - niski sygnał
P0563 P0233 Napięcie zasilania systemu - wysoki sygnał
P0565 P0235 Układ ster. prędkością, sygnał ON - usterka
P0566 P0236 Układ ster. prędkością, sygnał OFF - usterka
P0567 P0237 Układ ster. prędkością, sygnał RESUME - usterka
P0568 P0238 Układ ster. prędkością, sygnał SET - usterka
P0569 P0239 Układ ster. prędkością, sygnał COAST - usterka
P0570 P023A Układ ster. prędkością, sygnał ACCEL - usterka
P0571 P023B Układ ster. prędkością /przełącznik A hamulca - usterka
P0572 P023C Układ ster. prędkością /przełącznik A hamulca - niski sygnał wejściowy
P0573 P023D Układ ster. prędkością /przełącznik A hamulca - wysoki sygnał wejściowy
P0574 P023E Układ ster. prędkością (Cruise Control)
P0575 P023F Układ ster. prędkością (Cruise Control)
P0576 P0240 Układ ster. prędkością (Cruise Control)
P0577 P0241 Układ ster. prędkością (Cruise Control)
P0578 P0242 Układ ster. prędkością (Cruise Control)
P0579 P0243 Układ ster. prędkością (Cruise Control)
P0580 P0244 Układ ster. prędkością (Cruise Control)
P0600 P0258 Szeregowe łącze komunikacyjne - usterka
P0601 P0259 Wewnętrzny moduł sterujący - błąd sumy kontrolnej pamięci
P0602 P025A Wewnętrzny moduł sterujący - błąd programowania
P0603 P025B Wewnętrzny moduł sterujący - błąd pamięci podtrzymywanej (KAM)
P0604 P025C Wewnętrzny moduł sterujący - błąd pamięci o dostępie swobodnym (RAM)
P0605 P025D Wewnętrzny moduł sterujący - błąd pamięci stałej (ROM)
P0606 P025E Procesor mudułu sterującego ECM/PCM - usterka
P0608 P0260 Wyjście A sygnału predkości (VSS) modułu sterującego
P0609 P0261 Wyjście B sygnału prędkości (VSS) modułu sterującego
P0620 P026C Obwód sterujący alternatora - usterka
P0621 P026D Obwód sterujący L lampą alternatora - usterka
P0622 P026E Obwód sterujący F polem alternatora - usterka
P0650 P028A Obwód sterujący lampki uszkodzeń MIL - usterka
P0654 P028E Obwód wyjściowy prędkości obrotowej silnika - usterka
P0655 P028F Obwód wyjściowy lampki przegrzania silnika - usterka
P0656 P0290 Obwódu wyjściowy poziomu paliwa - usterka
P0700 P02BC System kontroli przełożenia /przenoszenia napędu/ - usterka
P0701 P02BD System kontroli przełożenia /przenoszenia napędu/ - sygnał poza zakresem/wydajność
P0702 P02BE System kontroli przełożenia /przenoszenia napędu/ - usterka elektryczna
P0703 P02BF Przetwornik momentu obr./przełącznik B hamulca - usterka
P0704 P02C0 Obwód wejściowy przełącznika sprzęgła - usterka
P0705 P02C1 Czujnik zakresu przełożenia - usterka
P0706 P02C2 Czujnik zakresu przełożenia - sygnał poza zakresem/wydajność
P0707 P02C3 Czujnik zakresu przełożenia - niskie wejście
P0708 P02C4 Czujnik zakresu przełożenia - wysokie wejście
P0709 P02C5 Czujnik zakresu przełożenia - przerwa
P0710 P02C6 Czujnik temp. cieczy przekładniowej - usterka
P0711 P02C7 Czujnik temp. cieczy przekładniowej - sygnał poza zakresem/wydajność
P0712 P02C8 Czujnik temp. cieczy przekładniowej - niski sygnał wejściowy
P0713 P02C9 Czujnik temp. cieczy przekładniowej - wysoki sygnał wejściowy
P0714 P02CA Czujnik temp. cieczy przekładniowej - przerwa
P0715 P02CB Czujnik prędkości wejściowej turbiny - usterka
P0716 P02CC Czujnik prędkości wejściowej turbiny - sygnał poza zakresem/wydajność
P0717 P02CD Czujnik prędkości wejściowej turbiny - brak sygnału
P0718 P02CE Czujnik prędkości wejściowej turbiny - przerwa
P0719 P02CF Przetwornik momentu obr./przełącznik B hamulca - niski sygnał
P0720 P02D0 Obwód wyjściowy prędkości silnika - usterka
P0721 P02D1 Obwód wyjściowy prędkości silnika - sygnał poza zakresem/wydajność
P0722 P02D2 Obwód wyjściowy prędkości silnika - brak sygnału
P0723 P02D3 Obwód wyjściowy prędkości silnika - przerwa
P0724 P02D4 Przetwornik momentu obr./przełącznik B hamulca - wysoki sygnał
P0725 P02D5 Obwód wejściowy prędkości silnika - usterka
P0726 P02D6 Obwód wejściowy prędkości silnika - sygnał poza zakresem/wydajność
P0727 P02D7 Obwód wejściowy prędkości silnika - brak sygnału
P0728 P02D8 Obwód wejściowy prędkości silnika - przerwa
P0730 P02DA Błędne przełożenie biegu
P0731 P02DB Błędne przełożenie biegu 1
P0732 P02DC Błędne przełożenie biegu 2
P0733 P02DD Błędne przełożenie biegu 3
P0734 P02DE Błędne przełożenie biegu 4
P0735 P02DF Błędne przełożenie biegu 5
P0736 P02E0 Błędne przełożenie biegu wstecznego
P0740 P02E4 Sprzęgło przetwornika momentu - usterka
P0741 P02E5 Sprzęgło przetwornika momentu - problemy z osiągami lub zatrzymanie
P0742 P02E6 Sprzęgło przetwornika momentu - problemy z wciągnięciem
P0743 P02E7 Sprzęgło przetwornika momentu - usterka elektryczna
P0744 P02E8 Sprzęgło przetwornika momentu - przerwa
P0745 P02E9 Elektromagnes/cewka kontroli ciśnienia - usterka
P0746 P02EA Elektromagnes/cewka kontroli ciśnienia - problemy z osiągami lub zatrzymanie
P0747 P02EB Elektromagnes/cewka kontroli ciśnienia - problemy z wciągnięciem
P0748 P02EC Elektromagnes/cewka kontroli ciśnienia - usterka elektryczna
P0749 P02ED Elektromagnes/cewka kontroli ciśnienia - przerwa
P0750 P02EE Elektromagnes/cewka przesuwu A - usterka
P0751 P02EF Elektromagnes/cewka przesuwu A - problemy z osiągami lub zatrzymanie
P0752 P02F0 Elektromagnes/cewka przesuwu A - zatrzymanie
P0753 P02F1 Elektromagnes/cewka przesuwu A - usterka elektryczna
P0754 P02F2 Elektromagnes/cewka przesuwu A - przerwa
P0755 P02F3 Elektromagnes/cewka przesuwu B - usterka
P0756 P02F4 Elektromagnes/cewka przesuwu B - problemy z osiągami lub zatrzymanie
P0757 P02F5 Elektromagnes/cewka przesuwu B - zatrzymanie
P0758 P02F6 Elektromagnes/cewka przesuwu B - usterka elektryczna
P0759 P02F7 Elektromagnes/cewka przesuwu B - przerwa
P0760 P02F8 Elektromagnes/cewka przesuwu C - usterka
P0761 P02F9 Elektromagnes/cewka przesuwu C - problemy z osiągami lub zatrzymanie
P0762 P02FA Elektromagnes/cewka przesuwu C - zatrzymanie
P0763 P02FB Elektromagnes/cewka przesuwu C - usterka elektryczna
P0764 P02FC Elektromagnes/cewka przesuwu C - przerwa
P0765 P02FD Elektromagnes/cewka przesuwu D - usterka
P0766 P02FE Elektromagnes/cewka przesuwu D - problemy z osiągami lub zatrzymanie
P0767 P02FF Elektromagnes/cewka przesuwu D - zatrzymanie
P0768 P0300 Elektromagnes/cewka przesuwu D - usterka elektryczna
P0769 P0301 Elektromagnes/cewka przesuwu D - przerwa
P0770 P0302 Elektromagnes/cewka przesuwu E - usterka
P0771 P0303 Elektromagnes/cewka przesuwu E - problemy z osiągami lub zatrzymanie
P0772 P0304 Elektromagnes/cewka przesuwu E - zatrzymanie
P0773 P0305 Elektromagnes/cewka przesuwu E - usterka elektryczna
P0774 P0306 Elektromagnes/cewka przesuwu E - przerwa
P0775 P0307 Układ kontroli ciśnienia /cewka B - usterka
P0776 P0308 Układ kontroli ciśnienia /cewka B - problemy z osiągami lu
 Tytuł: Kody błędów
PostNapisane: 7 lis 2012, o 19:16
http://www.obd-codes.com/
Bardzo fajna strona....na samym dole w zakładce Pełna lista kodów...dzięki,której dowiemy się o objawach,przyczynach i skutkach błędów :-)
PostNapisane: 25 lip 2013, o 09:37
Model: Avensis t25 fl
Silnik: ADT250L-AWFEYW
Moze ktorys z szanownych modow podepnie ten post coby kazdy mogl sobie sam sprawdzic procedury przy bledach typu "P'
Tu link do listy :
http://toyota-corolla.ru/rm04f1ru/repai ... 00dx.html#
PostNapisane: 8 sty 2016, o 20:06
Dołączył(a): 7 gru 2014, o 19:40
Zapaliły się mi kontrolki vsc i track off w mojej ave d4d 2.0 03r. Samochód jeździ normalnie, lecz na komputerze błędu skasować nie idzie. Błąd P103 obwód przepływu strumienia masowego powietrza- wysoki. Czy miał ktoś podobny problem, chodzi mi czy może chodzic o przepływomierz ?
PostNapisane: 8 lut 2016, o 13:30
Dołączył(a): 24 sty 2015, o 13:06
Marka: honda
Model: 2000
Silnik: 1AZ-FS
PostNapisane: 11 lut 2016, o 13:18
Marka: honda
Model: 2000
Silnik: 1AZ-FS
Thanks for sharing this useful information :) ==== solitaire champ ====
PostNapisane: 12 lut 2016, o 15:09
Dołączył(a): 24 sty 2016, o 21:48
Model: t22
Silnik: 2,0 benzyna
Panowie. Mam problem. Wymieniałem filtr kabinowy, czyściłem pojemnik od filtra powietrza ( po wyjęciu filtra) i zapaliła mi się lampka silniczka. Ma wskazania tych błędów: 34; 41; 54 . Nie bardzo kojarzę co one moją oznaczać. Czy powyższe czynności mogły spowodować te błędy. Proszę znawców tematu o opinie. Pozdrawiam Jerk2.
Sprawa rozwiązana .Przy podnoszeniu wieka obudowy filtra wysunął sie trochę jakiś czujnik który jest wciśnięty do obudowy przez uszczelkę gumową- i w tym miejscu się do połowy wysunął. Pewnie silnik dostawał dodatkowe lewe powietrze i stąd te błędy.
PostNapisane: 26 lut 2016, o 10:37
Model: t22
Silnik: 2,0 benzyna
Temat powraca. Wczoraj robiłem trasę ok. 1000 km i w trakcie jazdy, po ok 350 km znów zaświeciła się kontrolka awaryjna, dziś sprawdziłem kody i wyszły te same 34; 41; 54 to już czarna magia dla mnie, czy może ktoś pomóc
PostNapisane: 26 lut 2016, o 11:10
Pochwały: 30
czynności, które opisałeś nie mają z tym nic wspólnego a raczej gdzieś czyjaś nieuwaga. Sprawdź sobie czy gdzieś nie masz uszkodzonego albo zdjętego węża sterującego actuatorem turbosprężarki.
PostNapisane: 26 lut 2016, o 14:15
Model: t22
Silnik: 2,0 benzyna
Ale ja nie mam turbo. Mam silnik 1AZFSE 2000CC 16-zaworowy DOHC EFI
PostNapisane: 27 lut 2016, o 09:36
Model: t22
Silnik: 2,0 benzyna
Czy ktoś może wie coś więcej w tym temacie??
PostNapisane: 27 lut 2016, o 10:06
Pochwały: 30
sorry, trochę nie doczytałem. Ale kody, które przytoczyłeś pojawiają się najczęściej w autach z turbo a już 54 dotyczy obwodu IC. Zatem chyba coś źle przeczytałeś. Najlepiej jakbyś podpiął jakiś tester i przeczytał DTC w systemie OBDII.
PostNapisane: 27 lut 2016, o 11:04
Model: t22
Silnik: 2,0 benzyna
To chyba muszę podjechać gdzieś na kompa
PostNapisane: 16 maja 2017, o 15:00
Dołączył(a): 17 lut 2007, o 22:34
MaŁy_RaDeK napisał(a):
Podstawowe kody błędów sygnalizowanych przez lampkę Check-Engine (Malfunction Indicator Lamp):
1 Normal Condition
2 Air Flow Meter signal
MANIFOLD AND/OR AIRFLOW METER SENSOR circuit
- AIRFLOW METER/circuit
- MANIFOLD PRESSURE SENSOR/circuit
3 Ignition signal
-NO "IGF" SIGNAL to ECM
-IGNITER/IGNITER CIRCUIT
-IGNITER AND IGNITION COIL/circuit
4 Engine Coolant Temperature Sensor signal
- OPEN or SHORT IN WATER TEMP. SENSOR
- WATER TEMPERATURE SENSOR circuit
5 Oxygen Sensor OXYGEN SENSOR SIGNAL/OXYGEN SENSOR HEATER Signal
OPEN OR SHORT IN OXYGEN SENSOR OR OXYGEN SENSOR Signal
6 RPM signal (Crank Angle Pulse) RPM Signal
- NO SIGNAL to ECU FROM DISTRIBUTOR ("Ne" or "G") AFTER ENGINE HAS BEEN CRANKED
- DISTRIBUTOR/circuit
- STARTERSIGNAL circuit
- IGNITER/IGNITER circuit
7 Throttle Position Sensor Signal
- OPEN or SHORT Signal
- TPS SENSOR
- TPS Signal/circuit
8 Intake Air Temperature Sensor Signal
- Open or short INTAKE AIR TEMP. SIGNAL
- INTAKE AIR TEMPERATURE circuit
- INTAKE AIR TEMPERATURE SENSOR
9 Vehicle Speed Sensor Signal
-NO SPD. SIGNAL FOR SEVERLA SECONDS WHILE VEHICLE IS OPERATED UNDER HEAVY LOAD
TPS/MAP/AIR FLOW INPUTS)
- SPEED SENSOR/circuit
10 Starter signal
11 Switch signal LOSS OF POWER SUPPLY TO ECM
-IGNITION SWITCH/circuit
-MAIN RELAY/circuit
12 Knock Control Sensor signal
STARTER SIGNAL
- NO "STA" SIGNAL TO ECM UNTIL ENGINE SPEED EXCEEDS 800 RPM
- IGNITION SWITCH/circuit
12 RPM signal (G22 for –FSE)
- NO SIGNAL TO ECM FROM DISTRIBUTOR ("Ne" OR "G") AFTER ENGINE HAS BEEN CRANKED
-IGNITER/IGNITER circuit
12 Crankshaft position (CKP) sensor - circuit malfunction (3C-TE)
13 Knock Control CPU (ECM)
13 RPM signal (NE for –FSE)
SAME AS above but after ENGINE has RUN AT 1,000 - 1,500 RPM
-DISTRIBUTOR/DISTRIBUTOR circuit
13 Fuel injection pump position sensor – circuit malfunction (3C-TE)
14 Turbocharger Pressure
14 Ignition signal
- No "IG" or "IGF" ignition signal to ECM from ignitior several times in succession (IGT1, IGT4, IGF for –FSE)
- NO "IGF" SIGNAL TO ECM
- IGNITER AND IGNITION COIL/circuit
14 (2C-TE) Timing control system malfunction
15 Ignition System (IGT2, IGT3, IGF for –FSE)
15 (1CD-FTV) Throttle motor - circuit malfunction
15 Throttle control circuit - malfunction
16 Faulity in transmission/transaxle ECM (Transmission control signal)
17 Engine control module (ECM) -malfunction
18 Fuel quantity adjuster -malfunction
19 Acceleration Pedal Position (AAP) Sensor/Switch circuit malfunction (VC, VPA, VPA2, E2 – for FSE, 3C-TE)
21 Oxygen Sensor
OXYGEN SENSOR SIGNAL/OXYGEN SENSOR HEATER SIGNAL
- OPEN or SHORT IN OXYGEN SENSOR OR OXYGEN SENSOR SIGNAL
22 Engine Coolant Temperature Sensor signal
- OPEN OR SHORT IN WATER TEMP. SENSOR SIGNAL
23 Intake Air Temperature Sensor signal
- OPEN OR SHORT IN INTAKE AIR TEMP. SIGNAL
24 Intake Air Temperature Sensor signal
25 Air-Fuel Ratio Lean
- LEAN SIGNAL SENT TO ECU FROM O2 SENSOR
- INJECTOR FAULT(S)
- FUEL PRESSURE
- OXYGEN SENSOR
- AIRFLOW METER OR MAP SENSOR
- IGNITION
26 Air-Fuel Ratio Rich
- SAME AS ABOVE
- COLD START INJECTOR
27 Sub Oxygen Sensor signal
- SUB OXYGEN SENSOR/HEATER circuit
28 No. 2 Oxygen Sensor signal
No.2 OXYGEN SENSOR/OXYGEN SENSOR HEATER
- SAME AS CODE 21
29 No. 2 Oxygen Sensor signal
31 Air Flow Meter signal or Vacuum Sensor signal circuit
- AIRFLOW METER/CIRCUIT
- MANIFOLD PRESSURE SENSOR (MAP) circuit
32 Air Flow Meter signal (VANE-TYPE)
32 (Diesel) Malfunction Resistance Signal
32 (2C-TE) Module coding plug - malfunction
32 (1CD-FTV) Injector - malfunction
33 IAC Valve
- OPEN OR SHORT IN IDLE AIR CONTROL VALVE Signal CIRCUIT or IDLE AIR CONTROL VALVE or ECM
33 Intake manifold air control solenoid –malfunction (3C-TE)
34 Turbocharger Pressure signal
- ABNORMAL TURBOCHARGER PRESSURE
- TURBO CHARGER
- AIRFLOW METER/MANIFOLD/TURBOCHARGER PRESSURE Signal
- INTERCOOLER SYSTEM
35 Turbocharger Pressure Sensor
- TURBOCHARGER PRESSURE SENSOR (Gas.)
35 Manifold Absolute Pressure Sensor (Diesel, 3C-TE)
35 HAC Sensor signal
-OPEN CIRCUIT IN HIGH ALTITUDE COMPENSATOR Signal
36 Sensor Combustion Pressure (Toyota Part No. 89468-20020)...
39 (Avensis) Fuel temperature sensor - circuit
39 VVT-i Valve (p1656,p1345,p1349, OCV for -FSE)
39 Fuel temperature sensor - circuit malfunction (3C-TE)
41 Throttle Position Sensor signal
- OPEN OR SHORT IN TPS Signal
- TPS Sensor
42 Vehicle Speed Sensor signal
- NO SPD. Signal for SEVERLA SECONDS WHILE VEHICLE IS OPERATED UNDER HEAVY LOAD (TPS/MAP/AIR FLOW INPUTS)
- SPEED Signal circuit
43 Starter signal
- NO "STA" Signal TO ECU until ENGINE SPEED exceeds 800 RPM
45 EGR System malfunction
- VSV EGR
- Temperature Sensor
47 Sub-Throttle Position Sensor
- Open or short circuit in Sub-Throttle position sensor signal
47 Throttle position (TP) sensor
48 Vacuum Switching Circuit of Air Sw. Valve or Air Pump (EAP) Malfunction
49 for D-4 System SFP (PR, VC, E2 for -FSE)
51 Switch signal
SWITCH Signal IDL (tps) CONTACTS OFF, NEUTRAL START SWITCH OFF, A/C SWITCH "ON" Signal TO ECM
WITH DIAGNOSTIC CHECK CONNECTOR SHORTED
- A/C SWITCH/circuit
- A/C AMPLIFIER
- TPS/CIRCUIT
- NEUTRAL START SWITCH/circuit
52 Knock Sensor signal
- OPEN OR SHORT IN KNOCK SENSOR Signal
- KNOCK SENSOR/circuit
53 Knock Control signal in ECM FAULTY or Engine control module (ECM) knock control – defective
(P1605)
54 Inter-cooler ECM signal
Intercooler coolant circulation capacity diminished (fail-safe operation: ignition timing program retarded by
2 degr.)
55 Knock Sensor signal
Open or short circuit in knock sensor signal (Chaser TRD with 2JZ-GTE)
56 Cooling Fan Pressure Sw.
58 SCVP, E2, SCV+, SCV (for –FSE)
59 VVT-i Valve - for FSE)
71 EGR System
EGR VALVE MALFUNCTION
- EXHAUST GAS TEMPEATURE BELOW SPEC. FOR EGR CONTROL
- EGR SYSTEM
- EGR GAS TEMPERATURE SENSOR circuit
72 Fuel Cut Solenoid signal
IGF SIGNAL IS DETECTED FOR 4 CONSECUTIVE IGNITIONS
72 A/C System (A/C Relay Open)
78 (Avensis) Fuel circuit - malfunction
78, 79 Fuel Pump Control signal (S+, E1 for FSE) (P1235
- Fuel Pump Control signal, P1200- Fuel Pump Relay/ECU Malfunction ?)
- Open or Short circuit in fuel Pump Control circuit or Fuel Pump Electronic Control Unit (ECU)
79 D-4
81 TCM Communication
- Open in ECT1 circuit between ECM & Transmission Control Module (TCM) for at Least 2 seconds
83 TCM Communication
- Open in ESA1 circuit between ECM & Transmission Control Module (TCM) for 1/2 second after engine
idles at least 1/2 second
84 TCM Communication
- Open in ESA2 circuit between ECM & Transmission Control Module (TCM) for 1/2 second after engine
85 TCM Communication
- Open in ESA3 circuit between ECM & Transmission Control Module (TCM) for 1/2 second after engine
89 (P1125, 1126, 1127, 1128) read a pulse ETCS-SNOW (Chaser TRD with 2JZ-GTE)
92 D-4 (p1210)
96 (p1600) Engine control module (ECM) -supply
97 D-4 (p1215) EDU Malfunction
97 (Avensis) Injector control module – circuit malfunction
98 D-4
99 (B2799) there is a trouble with immobilizer (for the OBDII-equiped Vechicle)
PostNapisane: 26 cze 2017, o 21:23
Dołączył(a): 7 sty 2013, o 22:04
Silnik: 7a-fe
Hej,
Nie zaczynając nowego tematu.
Ktoś byłby wstanie mi pomóc i wyjaśnić pokrótce co znaczą wykazane u mnie błędy?
Avensis T22 98r, 1.8 7a-fe + LPG
34 Sygnał cinienia turbosprężarki
- Nieprawidłowego cinienia TURBOSPRĘŻARKI
- TURBO CHARGER
- Przepływ powietrza m / KOLEKTOR / TURBOSPRĘŻARKI sygnału cinienia
- SYSTEM INTERCOOLER
39 Czujnik temperatury paliwa - usterka obwodu (3C-TE)
58 SCVP, E2, SCV +, SCV (for-FSE)
Z góry dziękuję.
PostNapisane: 29 lip 2017, o 15:17
Dołączył(a): 25 lip 2017, o 08:45
Silnik: 2,4 benzyna
Witam , prawdopodobnie mam uszkodzony zawór sterujący rb/g błąd P2008 , wie ktoś jakie są koszta części + wymiana w ASO , i po za . ?
Silnik 2,4 benzyna 2004 rok .
 Tytuł: Kody błędów
PostNapisane: 10 sie 2017, o 09:00
Dołączył(a): 3 sie 2017, o 14:03
Panowie mam problem z Avensis D4D 2.0 i może ktoś będzie potrafił mi pomóc.
Pojawiły się następujące błędy:
DTCs 0524 - opis nieznany kod usterki
oraz
DTCs C13A9 - system hamowania
C1201 - układ sterowania silnikiem
Czy ktoś spotkał się może z takimi błędami i może wie gdzie szukać ?
Marcin
Utwórz nowy wątek Odpowiedz w wątku  [ Posty: 23 ]
